fuel filter replacment
Old Jan 14, 2008 | 08:52 PM
  #21
dieselram's Avatar
dieselram
Default RE: fuel filter replacment
ORIGINAL: cujo
ORIGINAL: lilfroger
wonder how much of that $80 is the EPA charges for having to 'dispose' of the diesel
The sad thing is when I take my used oil and filters to my local recycler I don't have to pay for disposal, it's just another charge the dealer passes on to you for being their valued customer.[:@]
Last time I bought oil from wally-world, they charged me an oil disposal fee. I don't know if thats just a state thing, or if the EPA charges for disposal at purchase.
Old Jan 14, 2008 | 09:01 PM
  #22
Kev_n_AZ's Avatar
Kev_n_AZ
agargano98
glad to hear ya go the filter done up!
did ya fill the filter with fuel before installing it?
just curious. thats the way we do it on the 5.9's.
Old Jan 14, 2008 | 09:38 PM
  #23
Drew's Avatar
Drew
I dont fill mine. . .I just let the lift pump fill it for me
BTW, Ive seen about 2 different ways to change the fuel filter on the 6.7's. from pulling the canister apart and changing the filter, to replacing the entire canister.
Old Jan 14, 2008 | 09:50 PM
  #24
agargano98's Avatar
agargano98
no it says in bold lettering DO NOT PRE FILL THE FILTER. i coated the o-ring with motor oil, screw in the canister, to prime the filter i followed the steps in the owners manual.
392 MAINTAINING YOUR VEHICLE
Priming if the engine has run out of fuel
1. Add a substantial quantity of fuel to the tank 5 to 10
gallons (19L to 38L).
2. Crank the engine for 1 to 2 seconds. If the engine does
not start, then release the key or starter button back to the
RUN position (do not turn the key back to the OFF
position). The electric fuel transfer pump will continue to
run and purge air from the system for about 25 seconds.
After 25 seconds, attempt to start the engine again.
3. Start the engine using the Normal Starting Procedure.
4. Repeat the procedure if the engine does not start.
CAUTION!
Do not engage the starter motor for more than 15
seconds at a time. Allow two minutes between the
cranking intervals.
NOTE: The engine may run rough until the air is forced
from all the fuel lines.
Old Jan 14, 2008 | 09:52 PM
  #25
agargano98's Avatar
agargano98
the mopar filter is $15 at the dealer and is the complete canister
Old Jan 14, 2008 | 10:03 PM
  #26
Parts/Service's Avatar
Parts/Service
My guys never take the tire off or the inner fender out. Not exactly sure how they do it. But I will find out tomorrow and post a easier DIY.....
Old Jan 14, 2008 | 11:16 PM
  #27
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: Parts/Service
they sit back and open a cold one. then kick the tires and call it good
dont let Dave know I aquired a shot from the back lot of the "dealership" were he works
Old Jan 14, 2008 | 11:34 PM
  #28
agargano98's Avatar
agargano98
Old Jan 15, 2008 | 07:18 PM
  #29
agargano98's Avatar
agargano98
i have the 4X4 so there is enough space in the wheel well for me to lay on top of the tire so i don't have to remove it. wouldn't be able to do that on the 2WD. Uncomftorable but better then removing the tire.
Old Jan 15, 2008 | 07:28 PM
  #30
UpBranchLiner's Avatar
UpBranchLiner
The guy on the right has to be the banjo kid from Deliverence all grown up!
[/quote]
