Rear Diff Lube???
Old 01-21-2008, 04:40 PM
cj7 bob's Avatar
cj7 bob
cj7 bob is offline
Default Rear Diff Lube???
I was checking therearend lube level on my 03 CTD 4X4 2500 HD today and noticed it was more like 5W10 weight oil, it smells like gear lube but is very thin, even with the outside temp of about 30F. Is this right? Maybe with the limited slip diff that is the lube they use. There was some metal dust on the plug maganet but not a lot. I was checking it because I have a chatter in the back somewhere when I start out from a dead stop.
Do I have to go to the dealerand buy the Mopar brand or is there another good brand and type?
Old 01-21-2008, 04:45 PM
agargano98's Avatar
agargano98
agargano98 is offline
Default RE: Rear Diff Lube???
i use Royal Purple gear oil 75w-90
Old 01-21-2008, 04:51 PM
Drew's Avatar
Drew
Drew is offline
any 75-90 will work. . .but preferably use a good quality and stay away from the costal crap. . .I burned up the syncro's in my toyota with that **** they call oil.
no friction modifyer is needed since the LSD is a clutchless system, royal purple, amsoil, pensoil, any of your higher end oils will do good.
Old 01-21-2008, 05:02 PM
agargano98's Avatar
agargano98
and the Royal Purple costs $2 a quart less than the Mopar oil
Old 01-21-2008, 05:30 PM
Drew's Avatar
Drew
Drew is offline
oh, one more thing. . .the lube in the axels is synthetic from the factory
Old 01-22-2008, 01:52 AM
turbot_bird's Avatar
turbot_bird
turbot_bird is offline
ya, mine they recommend changing it at 20k is it the same for you guys in your rams?
Old 01-22-2008, 11:18 AM
DBLR's Avatar
DBLR
DBLR is offline
My 2006 is scheduled to be changed out at 15,000 miles for sever usage (Schedule A) or at 120,000 miles for normal usage (Schedule B). IIRC the 1500’s and Dakotas are now required to use 75/140-gear oil and not the 75/90 the 2500 and 3500 trucks use.
Old 01-22-2008, 01:03 PM
agargano98's Avatar
agargano98
my 07 the book says every 15000.
Old 01-22-2008, 06:43 PM
Diesel Man's Avatar
Diesel Man
Diesel Man is offline
Does anyone know how many quarts the rear difftakes and how many does the fron diff takes on a 07 6.7 4x4? I'm tring to avoid the hard hitting oil/labor cost of the dealership.
Old 01-22-2008, 06:51 PM
agargano98's Avatar
agargano98
i did my front and rear and it took 9 quarts for both.
Quick Reply: Rear Diff Lube???
