brakes pulling 98.5 3/4 ton
Old 03-02-2008, 11:44 PM
bmgstang's Avatar
bmgstang
bmgstang is offline
Default brakes pulling 98.5 3/4 ton
I'm no master mechanicso here's my situation: I pulled a heavy concrete trailer across town without a brake controller so this warped my brakes. I then had a terrible pulsation in the brake pedal. I only found onerotor to be catching on the pads so I replaced only this passenger side rotor (didn't want to chance replacing the hub on drivers side $$$$$). At the same time I replaced both side pads and calipers. I also went to change both brake lines but they gave me the wrong one for the drivers side so I only got the passenger side line changed. Now the pedal is smooth but the truck pulls really hard to the left with medium to hard brakeing. I would imagine the drivers side rotor could be warped causing that side to brake harder than the passenger side but the pedal is smooth, no pulsation. Any suggestions?
Old 03-03-2008, 12:15 AM
Mayfair's Avatar
Mayfair
Mayfair is offline
Default RE: brakes pulling 98.5 3/4 ton
I agree, I think you'll need to replace the drivers side rotor as well as the brake line.
Old 03-03-2008, 02:47 AM
bmgstang's Avatar
bmgstang
bmgstang is offline
Do you think it's possible for the rotor to be warped without the pedal pulsating?
Old 03-03-2008, 06:55 AM
HankL's Avatar
HankL
HankL is offline
it is a good idea to read this TSB
before tackling the problem:
http://dodgeram.info/tsb/1997/05-03-97/page1.html
Old 03-05-2008, 08:29 PM
bmgstang's Avatar
bmgstang
bmgstang is offline
I'm not sure what this TSB info means? All I know is my truck tracks down the road straight as can be until I apply the brakes with medium to hard pressure. I jacked up the front end today and spun the wheels, the passenger wheel spins almost freely just grazing the pads and the drivers side drags on the pads all the way around and this is the side that the truck pulls to. Also, on the driver side wheel when I go to spin it the wheel will shift just slightly before the rotor catches and spins. The passenger side does not do this, anybody know why this is?
Old 03-05-2008, 08:45 PM
05cumminscrx's Avatar
05cumminscrx
05cumminscrx is offline
are both calipers lubes up good so they slide back and forth and dont catch or hang up, obvioulsy one side is working harder then the other, brake lines would be worthless changing. i would replace the other rotor most likely your problem
Old 03-05-2008, 08:51 PM
bmgstang's Avatar
bmgstang
bmgstang is offline
Yeah the slide bolts are lubed up I'm probably going to try replacing the rotor and go from there. The only other thing I can think of is maybe I got a defective caliper on the passenger side? I'm betting on the rotor though.
Old 03-05-2008, 08:55 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Kev_n_AZ is offline
did you have the other rotor turned?
are the steering control arm bushings or any other front end item (ball joint) worn out??
Old 03-05-2008, 08:58 PM
bmgstang's Avatar
bmgstang
bmgstang is offline
No didn't turn the rotor just left it alone because of the hub and bearing issue with these trucks. The front end feels solid.
Old 03-05-2008, 09:00 PM
bmgstang's Avatar
bmgstang
bmgstang is offline
I'm thinking if I warped the one rotor bad enough as it was this other old rotor had to take some damage as well. I'm almost positive I need to change it so thats what I'm gonna try.
Quick Reply: brakes pulling 98.5 3/4 ton
