Fan clutch is out
Fan clutch is out
Well I went to look at it after it has been running un normal temps driving in the city. Found out the clutch is probably dead. I am taking it to a shop tomorrow(somewhere besides a dodge dealer!)
For 1: Where can I go to get this fixed? Goodyear?
2: is this from going mudding and from plowing through water, or do they just go bad?
Thanks!
Thanks!
RE: Fan clutch is out
Yes the radiator is super clean. I cleaned it up this morning. Are you sure it is electric? It looks like it is connected to the engine. My friends dad said that the fan clutch is bad on it.
This morning the fan kinda turned but would shut off every few seconds, then start back up, then shut off.... Now the fan will n ot turn at all. you cant even move it about 5in, after that it just wont turn...
Can anybody go see if you cn spin your fan with the engine cool? I need some help on what to do with this!
Thanks
Thanks
it is electric clutch there is a connector down below by the crankshaft pulley but it is driven by the engine via the belt and the fan pulley it is just electrically engaged. have seen wiring issues with some of these with the wiring or the connector corroding down by the crankshaft pulley and when it is cool you cannot turn it at all?
well austin you need to check the connector down by the pulley making sure no wires that lead from the shroud mount on the left side to the lower part of the radiator are intact. you may had done damage to the fan but very unlikely havent replaced any so far in the shop but have repaired alot of wiring harnesses in this area i should have asked you have a P0483 fan speed code? could be wrong but i would check those wires. also would leave it stock but it is up to you if you modify just another thing to go wrong that you have changed. check those wires austin or have someone do it for you
Trending Topics
Yeah it put out a p0483 code. That was when the fan was somewhat working.
Went out and looked, all the wires are there and are connected good. the fan seems like it is rubbing though. I will take it to goodyear and see what they say.
What can cause this to happen though?
No they can't really do anything. I bought the truck, and if I damage it I am the one that pays for it. It will be out of the shop today with a $525 charge. I think it should be lower than that, but they have to get the whole assembly. The reason for the speeding ticket was my fault, but I didn't want to stop every 5miles to let it cool down. First time I have ever seen a cop there... []Oh well, live and learn.
These tickets and repairs are adding up!!! My dad won't let me go mudding for a month, thats my punishment, which sucks because I havent had the truck long at all!
