Another oil change rant
RE: Another oil change rant
ORIGINAL: dirtydodge02
Hmm... Guess I'ma square too. (Psst... Donny, where you pick that up at??Sounds like a blessing to me!)
I've got the old fashioned screw in plug yet and will NEVER change it... I agree it just too easy for a branch or twig to snap off some hanging down from the oil pan. I've got rub marks where twigs and sticks have smacked the oil pan... I don't suggest anyone getting a quick drain that does any kind of offroading...
For example...
I've even got small dents in my floorboards from sticks and rocks hitting the floor... The larrgest one required me to beat the dent out of the passenger rear floor with a sledgehammer!!! [:-]
For example...
I'm new around here, but I like the idea of the quick drain. I had a Fram Sure Drain on an old Honda that was a bear to deal with. I recall that it took a long time to drain several quarts of oil. I see the concern about accidental triggers with the version with the lever, but what about this version?
http://www.genosgarage.com/prodinfo....Z-DP-22MMPL-DG
Pricey, but it seems like it's got a low profile. It looks similar to the Fram. I guess that valve being inside the pan could be a potential issue? And you need to worry about losing the fitting that opens the valve. Anyone have this version, I wonder what kind of flow rate it gets ....
Maybe you need some lessons on off roading,when your running over stuff that punches in your floor board, I have climbed over 14 inch trees without a scratch on stock tires, but then I only had to cross over seven going in and then turned around for fun,besides a few like scratches I had to buff out of the paint afterward.
But I left the hammer in the box
