got a boost question
Old 04-27-2008, 05:13 PM
YAMAHARIDER5's Avatar
YAMAHARIDER5
YAMAHARIDER5 is offline
Default got a boost question
Okay so i have installed my aurura 3000 turbo,air dog fuel pump, and my truck also has a edge comp cold air intake 75 horse jammer injector nozzels and with the factory turbo i could hit 35 psi now with the new aurura 3000 i can still only hit 35 psi with the edge on five five and wot so my question is that normal or am i missing something? i figured when i got the new turbo etc that i would be past the 35 mark.
Old 04-27-2008, 05:25 PM
firemedic740's Avatar
firemedic740
firemedic740 is offline
Default RE: got a boost question
is the max boost set at 35psi on the edge? I know I can set my max on the juice, don't know anything about the comp box.
Old 04-27-2008, 05:26 PM
YAMAHARIDER5
well from what ive been told my edge comp has five sublevels which are defuel setting and ive got that set to five which is suppose to be no defuel and then the main setting is five which is max power
Old 04-27-2008, 05:30 PM
firemedic740
Wish I could help you out more, but the guys herewill catch on to the thread and help you out.
Old 04-27-2008, 05:55 PM
Drew's Avatar
Drew
Drew is offline
that aurura 3000 may have the same boost levels. . .however it is capable of flowing more air. do you have black smoke from the exhaust??? if you do you may need to up the boost limit on your edge.
Old 04-27-2008, 06:02 PM
YAMAHARIDER5
how do i turn the edge comp up? And yeah i have an enormous amout of black smoke im talking i can close down whole intersections
Old 04-27-2008, 06:06 PM
Drew's Avatar
Drew
Drew is offline
sounds like you dont have enough air on the low end. . .hows the upper end smoke???
you may need a programmer to spool the turbo up quicker
Old 04-27-2008, 06:12 PM
YAMAHARIDER5
well if i windit up iloose the smoke at about 25 psi after that theirs isnt much till i change gears i get alittle puff then it starts again till sixth gear
Old 04-27-2008, 06:54 PM
YAMAHARIDER5
the aurura 3000 is suppose to max out at 42psi and support 575 rear wheel horse power. if i do need a programmer which on can i stack wit my edge comp
Old 04-27-2008, 07:04 PM
Drew's Avatar
Drew
Drew is offline
I'd say either bully dog or smarty.
Quick Reply: got a boost question
