1st check engine light
RE: 1st check engine light
With the truck off, insert the key, turn to the ON position (NOT START) 3 times. On the third time, leave it in the ON position. The 'P'code will show in the digital read out portion of your dash. Once you know what the P-code is you will have to find out what it means. I think there is a list on this site somewhere. Good luck.
Wait, wait, wait. Check the MAP sensor connection before you go to the dealer. It should be right near the intake horn, behind and down a few inches. Also, check the waste gate connection from the turbo itself. The wire should be below the turbo and runs slightly to the front. It may just be a loose connection.
Trending Topics
RE: 1st check engine light*** Updated***Dealerships Ruling
Its my intake and exhaust!!!!!
They are saying...and i Quote!!!!!!! " Modified exhaust will not allow enought backpressure, therefore the system will not perform right!!!!"
And they charged me 115.00!!!!! Kinda funny that there is a TSB out for that code!!!!
