Death Wobble
Old Mar 13, 2010 | 12:39 PM
  #51
Black Knight transport's Avatar
Originally Posted by steve05ram360
If you end up helping him, go under there and adjust the caster to rotate the axle forward... pinion up. do not get too crazy with the pinion angle, should be pretty close to 0* (a few deg off should be OK, avoid pinion bearing noise).
I have had just about every part worn or trashed on the front of 2 rams & never had a DW issue while having the caster set at 5.0 or greater.... the 2nd gen ram had 34" tires, 3rd gen had 325-60-18's that weighed a ton.
Humm!!!! all i know is that the line on the cam that is on the right and left side is at about 11 o'clock or one line back from the top...
Old Mar 13, 2010 | 12:53 PM
  #52
Originally Posted by pizzo
Dude Where are you at in Chicago.. I am on the Southside of Chicago If you need a hand Pm I can stop by and help out if needed... It could be many different things that is causing it I see that you have changed a lot of parts already. I have only had one truck with death wobble and it turned out to be drag link was bad... I am not saying this is your problem but If you need help I will drive out to where ever you are and check it out...
Yeah man that would be sweet!! Im up in buffalo grove but i work out of Indiana. I pull camper's and transport hotshot loads all over the u.s. with this thing so yeah!!! i need this fixed a.s.a.p. Ill try messing with the caster first and ill let you know how that go's.
Old Mar 13, 2010 | 04:12 PM
  #53
dodgegirl05's Avatar
dodgegirl05
ive had the same problem, its actually doing it right now. i replaced my tie rod on the driver side and it went away! looks like ill be doing them again! lol
Old Mar 13, 2010 | 06:32 PM
  #54
Nice!!! good call!!! tried to adj. the cam and the only thing that moved was the bushing. I think its time to replace it...
Old Mar 13, 2010 | 06:37 PM
  #55
Did you try replacing the track bar bushings? You can get the a two pice kit from napa for about 30 bucks. You will need a press to push the old ones out.
Old Mar 13, 2010 | 06:45 PM
  #56
Old Mar 16, 2010 | 08:34 PM
  #57
pizzo's Avatar
pizzo
I assume you got it fixed? I am on the very southeast side of Chicago. End of the Skyway. I see you hot shot guys coming from Elkhart In all the time with Campers.. I haul boats out with my 04.5 3500
Old Mar 27, 2010 | 05:46 PM
  #58
q5moe's Avatar
q5moe
Did you get your DW fixed? If so, what else did you do?
Old Mar 27, 2010 | 05:48 PM
  #59
q5moe's Avatar
q5moe
Default Death Wobble
That was meant for Black Knight Transport, sorry, new to this!!!
Old Mar 28, 2010 | 12:55 PM
  #60
Bad tires and lower control arm bushings... Hummmm???? Who would have thonk???
