Injectors: replace them all?
I've got an '06 CTD with about 70k on the clock. I have 1 bad injector that the dealership is going to replace under warranty. The service manager is strongly suggesting that I have all of the injectors replaced ($2,600) while they are in there. My question is: do I need to do all of them or can I get by with only replacing the bad 1???
it really is a good idea to replace them all rather than just one at a time, so you have a "matched set" but on the other hand it really doesnt hurt anything to do just one, really the worst that happens is a slight idle shake, but at that price i but you could find a set of aftermarket injectors that will net you more power and mpg's while still being quite a bit cheaper....
The injectors in any diesel trying to burn crank case gases and sludge as demanded by the EPA will fail very quickly.
They are rusting from the moisture created in the crank case pan
being fed into the fuel stream.
Nothing you can do about this problem as long as you deal
with the dealer/stealer.
That makes no sense at all. First off moisture from the crankcase never enters the fuel system. Secondly any moisture that would enter the combustion chamber wouldn't hurt anything, it wouldn't be enough to hurt anything. I have yet to see a rusty injector tip, most go bad from dirty fuel.
Trending Topics
The 06 doesn't have the egr and I dont think just the crankcase ventilation gasses are enough the hurt anything. The egr on the other hand is the worst thing that you can have on a diesel. My 03 6.0 ford got completely gummed up in the intake manifold and heads that it would not even run, but I remedied that little situation, now runs like a singer sowing machine.
crankcase gasses are vented not burned, and i inject water in my engine it loves it and the dealer is not the only place to jet your injectors worked on, just about anyone can do that
I am glad all you experts know everything, go visit a fuel injection service and look at some injectors removed your 6.7 and later. None of what you say about crank case gas not being fed back into the fuel system is crap.
After 2004 the epa required what had been trapped by puke tubes and by pass vent pipes had to be reburned...thus the problem !
enjoy your problem, my 5.9 2000 does not have the problem each of you face. Quit drinking dealer kool-aid.
