Axle wrap (hop)
Old May 24, 2020 | 12:43 PM
gonsnow's Avatar
gonsnow
Default Axle wrap (hop)
I have a 2010 Dodge Ram 3500 Cummins w/auto. I bought it new and ever since I have owned it when I get in snow pulling a trailer in 4wd up in the mountains at slow speed when ever it breaks loose I get severe hop in the rear. This has caused me to get stuck more than once because of the need to let up and stop the hop. Has anyone else had this problem and what did you do to fix the issue?
Old May 24, 2020 | 03:14 PM
Have a limited slip rear end in it?
Old May 24, 2020 | 09:21 PM
gonsnow's Avatar
gonsnow
Yes it does
Old May 25, 2020 | 08:21 AM
Hhhhmmmm..... How old are the shocks? Is the truck lifted at all?
Old May 25, 2020 | 09:22 AM
gonsnow's Avatar
gonsnow
Everything is original equipment 47K miles on truck. Only use it for towing is why miles so low. Did it with the original Michelins and now I have Cooper ATX on it and it still does it
Old May 25, 2020 | 10:10 AM
Coils or leafs in back? Think I would start with new shocks.......
Old May 25, 2020 | 07:31 PM
gonsnow's Avatar
gonsnow
Leaf springs no sway bar in rear not that that matters
Old May 25, 2020 | 07:57 PM
Is dodge still using blocks between the axle and springs to get the right ride height? If they are, might consider a shackle flip, and eliminate the blocks. They give the axle a nice lever to twist the springs around with.....
Old May 26, 2020 | 09:04 AM
ol' grouch's Avatar
ol' grouch
I'll bet your rear shocks are worn. They wear out slow so you don't notice it, but when you replace them, you notice the difference big time.
