03 ram sluggish
03-10-2021 | 03:11 PM
03 ram sluggish
My 3500 started with a very sluggish take off, but then shifts perfectly . help
03-11-2021 | 07:35 AM
Compared to what? Mileage? Last tune up? Did this just start happening? You need to provide more info in order for us to assist you.
03-12-2021 | 06:44 AM
03 3500 ram dually very sluggish at take 3
Quote:
when we changed the solenoid pressure switch, then it started being sluggish at take off
03-12-2021 | 07:29 AM
03-12-2021 | 09:22 AM
What engine/trans?
5.9 engine and Allison Trans. 6 cylinder
03-12-2021 | 06:17 PM
Ah, der diesel..... All the tubing for the turbo intact?
03-12-2021 | 10:20 PM
yes, all tubing is intact. It starts off in 2nd gear
03-13-2021 | 09:15 AM
That would definitely make it sluggish..... getting any trans codes?? I don't know squat about the allison trans.....
03-13-2021 | 10:20 AM
code says po700
03-13-2021 | 10:25 AM
That's a pretty generic code, and could mean all sorts of things.... Usually, there will be another code along with it, that points to what the actual problem is. If you don't have another code, reset codes, go for a drive. See if the code immediately resets.
