Turbo issues? Help
Turbo issues? Help
Hello everyone,
I have a 99 Ram with 5.9 Cummings all stock. I have an Intermittent problem with my turbo. Sometimes when I start engine and get going down the road I notice that the turbo is not spinning up. This is an obvious sign with such a huge loss of power, usually when this happens the check engine light will come on along with that. After driving for a few minutes (but sometimes has taken a day) eventually the turbo will kick in again and start spinning up and running as normal, along with the check engine light (quite some time later) going back off. I can never seem to catch the code before the check engine light goes back off. Just wondering if anyone has experienced this before. If so, what was your problem. Possible signs of turbo starting to go? Any info/help would be greatly appreciated.
Thanks
Thanks
RE: Turbo issues? Help
Had the same problem about a month ago, right after I bought my 99. Would be going down the road and it would loos all power, it might come back or it could take a couple days. Auto Zone can chech for the code even if the light isnt on, mine was 238 (I think). I ended up replacing the MAP Sensor and that took care of the problem. My milage went up quite a bit too.
Troy
Troy
Thanks for the responses tob and tc. I really appreciate the input. Tried the cycle and it didn't work, and yes I do have digital odometer. SES light was on as well again. Anywho, I will try to hit auto zone when the light is on if i'm near one to pull a code, but from all the research I've done, it does seem like its the MAP Sensor. So if it is that, is this something that a regular shade tree person like me can handle or should I leave it to the pro's? Also, (tcarothers) how much did your MAP sensor cost? This is my first Diseal engine...........not as familiar with compared to gas.
Once again, thanks for the help all
Farfree, You need a 1 1/4 in deep socket to take the map sensor out. It is located on the drivers side back of the block, it looks like a temp or oil pressure sending unit and has a wire harness that has 3 wires and the connector is triangular shaped. Easy to replace. Dealer told me 320.00$ (Bunch of B.S.), go to a local truck shop, they should be able to get it for you for about 60.00$ give or take. Parts stores dont have them, they come from Cummins. Good luck
Troy
Troy
so is it the map sensor telling the pcm that there is max boost and it's keeping the wastegate open? I'm trying to grasp how a map sensor would affect the boost levels... I think the wastegate is pcm controlled but i'm not 100% sure...
any experts care to shed some light on this?
Ok all,
I finally got a chance to stop by the auto parts store and pull the codes..........Here is the print out........just as I expected them to be.
If I could get your opinions on these, I would greatly appreciate it. TC, do you still think its the MAP sensor? It looks like it is to me
[IMG]local://upfiles/34986/243702B389E5436088113C75DDC756F4.gif[/IMG]
Trending Topics
these guys are right, replace the MAP sensor.
what is going on is the MAP sensor is reporting to the computer over 5v. when this happens the computer goes into an engine protection mode and will only fuel to rpm to keep the engine running.
after a few miles the computer will start checking the MAP sensor and will then fuel to boost once again. Ive gotten my truck to do it while Ive been messing with my MAP sensor with some resistor mods Ive been working on.
