DIY Maintenance: Fuel Filter
Old Sep 14, 2006 | 06:22 PM
  #41
steve05ram360's Avatar
steve05ram360
Default RE: DIY Maintenance: Fuel Filter
welcome to DF...
the silencer ring is a piece mounted on the turbo that reduces the turbo whine. if you yank it, you'll hear it much better.
Old Sep 15, 2006 | 08:49 AM
  #42
thralkhan's Avatar
thralkhan
does it improve performance or just give it a better sound? Like back in the day when we used to flip the top of the air cleaner on the carb engines?
Thanks, this is a great forum and I'm looking forward to more tech posts like this one...maybe in another thread someone can post how to remove the silencer ring
Old Sep 15, 2006 | 02:19 PM
  #43
DBLR's Avatar
DBLR
Taking it out is for sound. I don't think in will increase mpg.
Welcome to the Cummins Forum, you will find all the info you will need here. FYI, Drew is our expert and if you have any Q's just ask and we will do our best to help you out.
Old Sep 27, 2006 | 02:31 AM
  #44
JT824Megacab's Avatar
JT824Megacab
Just changed my fuel filter via the info on this site. It went very smooth, I have 13,000 miles and feel good that I was able to do it myself. I bought the filter from Napa but I am going to place an order with Geno's garage.
Thanks again!!!
Old Oct 7, 2006 | 06:20 PM
  #45
DBLR's Avatar
DBLR
I finally changed my filter today 10,200 miles and it was almost as black as Steves was. It was a breeze to change out and I had no problems starting it after the change [sm=bounceybounce.gif]
Old Oct 18, 2006 | 05:33 PM
  #46
ljpierce_ely's Avatar
ljpierce_ely
Drew AND Steve,
First off, Drew: Mucho thanks on the DIY info. Quite good and detailed. Did it without any hitches. Didn't have the socket you mentioned but a 30 MM socket I did have worked just fine.
Steve, my filter was somewhat darker than yours. Still need to do the priming sequence that Drew described. Again, I'll let you know how it all went.
Old Oct 18, 2006 | 06:28 PM
  #47
ljpierce_ely
Drew,
YOU THE MAN!!! I bow in the presence of greatness!!![sm=hail.gif]
Priming sequence worked perfectly. But the second lift time after bumping the starter was QUITE A BIT longer than I expected. Around 20 - 30 seconds. Was beginning to worry! Guess I need to learn to RELAX.
Again, many thanks on the detailed and simple instructions.
Old Oct 19, 2006 | 12:48 AM
  #48
gtxpooch's Avatar
gtxpooch
I checked to see if there was any water in mine today(4600miles) and nothing came out, no fuel no nothing. Did I not leave the valve open long enough? I counted to 10 by thousands??
Old Oct 19, 2006 | 12:23 PM
  #49
Drew's Avatar
Drew
check the hose and make sure a dirt daubber didnt build a nest in it.
Old Oct 22, 2006 | 01:35 AM
  #50
Mayfair's Avatar
Mayfair
Tomorrow's the day that I will be attempting this with my friends help.
Wish me luck !!
