Fogs On W/ High Beams...
I know I saw somewhere here the mod where you use a jumper wire & connect a couple of terminals on 2 different relays so that the fogs can stay on with the high beams. I believe it was one in of the gasser sections. Can this be done with the CTD? This may sound stupid and/or I may be blind, but I can't find any relays on my truck. There's none in the underhood fuse block. Any idea how I can accomplish this? Thank you!
Scott
Scott
no relays in the fuse box? that sounds strange. there must be another box somewhere that has them.
go here http://www.hemitruckclub.com/ and on the left side of the page is a link to download the '06 service manual. that should have enough info for you to get what you want done.
Thanks for the link. For some reason I can't open it. I'll tinker around & look a little harder for the relays but man I just did not see them. Maybe their buried under the dash somewhere but I didn't see them while I was hooking up my brake controller either. I'm sure there's a trick to this.
Scott
Scott
I do not know if the dealer will do it for you, They will do the idle up (So I read), My Bullydog programmer has the( high beam/fog light ) so I would say the dealer can, It does say for off road use only, So tell them thats what you are going to use it for.......
No wonder twotrack couldn't open the darn thing - it's over 9000 pages in Adobe! But it's the whole manual - nice to have if you have the room. But now I still have to find where in the wiring diagrams the relay and fuse box is, and then figure out what pins to jump...
Anybody do this already to save me a ton of reading?
Again, I was paging through Geno's garage, they have all sorts of options that plug into the harness.
Aparently the left and right head lights '05-'07? operate on their own systems, Geno's supplies relays for them both as a kit.
Also have the option having all three running at the same time - high, dim and fog lights. - Pretty cool!!
Trending Topics
The gasser discussion (and pics) was for an '04 - later years are different.
The Geno's Garage kit looks like a good way to go - if you don't mind forking out the $189 bucks they want for it for Fogs, Lows, and Highs. If I don't get someone coming up with a jumper soon, I think I'll just go for the kit from Geno's - thanks Nelspruit...
I'll ask my dad if the DRB machine can do that to an 06. If he can, I'm going to have a few things done to mine in hunting season. I can't get the stinkin locks to unluck (all doors) by programing the key faub myself. I'll let you know if I talk to him this weekend.
