stumped
i own a 2001 dodge ram van 1500 with a 3.9 litre engine 6 cylinder 6400 miles on her for the last 4 month the check engine light has been comming on my machenic puts his scanner on it and it comes back either misfire on cyl #5 or random misfires so i changed the distibuter cap rotor , plugs and wires it runs fine till i take it on the highway and the dam cel comes on as random misfires i am on my third distibuter cap no more cheap ones brass contacs where do i go from here thanks in advance arty
A lot of us have experienced that problem here. The engine management electronics could be causing trouble, or you could have another more serious problem like a vacuum leak or possibly a compression issue.
My CEL has been on for six months and I still can't track down my random misfire trouble. Another guy on this forum has changed every part he can think of, even those that have very little to do with a misfire issue, and his CEL is still on after many months (years?) without resolution.
This can be a tough problem to fix -- sorry I could not be more help.
I'm "the other guy."
I might have a clue to the cause of the problem. I have not fully verified it yet simply because I haven't had enough free time to get around to it. My #2 plug started misfiring like crazy and everything pointed to the injector leaking. I changed the injector which didn't solve the problem. So my attention went back to the spark plug with only 2500 miles on it. I took the plug out, which wasn't easy because the threads were carboned up. Once out I was able to test the plug and it worked perfectly. When trying to reinstall the plug I was having difficulty screwing it in. I took it back out and ran a spark plug thread chaser through the plug hole. After that I was able to spin the plug in with my finger. The #2 misfire is now gone. So my new theory is that the misfiring spark plug threads are carboned up and not making a good bond to ground. I am going to test this by removing all of the other 7 spark plugs and running the thread chaser through the plug holes to see if the misfires go away.
ok thanks guys for the advice.... i will pull out my new plugs and make sure they are fully threaded in and seated right it is worth a shot.... and i have been following your threads on this issue boy is it frustrating thanks arty
Maybe someone needs to invent a spark plug with two connections; one for the center electrode and one for ground?
Other than some changes in materials and electrode design the spark plug has remained basically unchanged for over 100 years.
Trending Topics
i have a v6 3.9 i was very careful routing the wires and i added that snake wrapping over the whole lenth of my cables i plan on taking the plugs out one at a time and cleaning the threads this saturday i will let you know how i made out thanks arty
I took the plugs out and ran a thread chaser in each hole. The misfire count did drop by half, but it's still there. When I did the #2 cylinder the other day I also changed the spark plug but did not with the rest of them because I wanted to see if just cleaning the threads helped. So maybe I need to try new plugs too even though these aren't that old.
I do have the V6 3.9 engine.
