5.2L Ram Motor In Dakota?
Jimbo I don't want a 5.9 it's too much gas, a 5.2L should break even with what I currently get with my 3.9LA
Yup a 97' was the wiring and computer I'm after since it is OBDII (programmable for aftermarket cam) yet it does not have the central timer module system (digital odometer etc). So ONLY the 36RH? Will I find one in a 97' Ram or Dakota?
NO. Most were OD tranny's which have the E instead of the H at the end of their model number. You will need to look at the dash for the OD on/off switch to the left of the steering colum on the dash panel to see if the donor van has OD or not. If so then skip it and look for one without the switch. The spot will be closed off. If you find an open hole then be carefull that someone has not removed the switch for their vehicle.
