New PCM recomendation/advice
I might need a new PCM for my 1994 B350 5.9L V8. There is a CARDONE reman down the street at my local parts store for $220. Also I could order a used PCM (exact part# as OEM) for $90. What are your guys thoughts on CARDONE, using a remanufactured PCM that may have a 1 year warranty, and using a used PCM out of a pick-n-pull that is only under warranty for 30 days?? Any thoughts or experiences with this are much appreciated!
Thank you for your time!
Rock Auto only has the A1 Cardone reman for $205. Another online dealer has a used on they say is tested and in good working condition for $90 off of a salvage vehicle from an accident. Im hearing that the Cardone remans are no good and to hope I get a good one if I order from them...
The other is cheaper but used, so how old is it? How did they test it to be sure it is working correct? You can try and return it but is there another to replace it? If no, then you get your money back and have to choose parts place or online or wherever anyway... if time is not an issue then have at it.
If it does work and solve the issue, keep it and pay for/exchange your Cardone for one that works and run the Cardone one. Keep the working OEM one for a backup, or vise versa, then you've got a spare.
Yes, I think so but I did not put it in. I have no idea where it came from. Also, it is the wrong part number. I got part #79-7174 off of it and this number only comes up on Cardone site but there is no Cardone label on the PCM. I've driven about 1000 miles total using this wrong part PCM and started to have problems after 300 miles. Previous owner says he knows nothing of changing pcm.
Trending Topics
Were it me I'd choose one or the other to see if it resolves the problem, no disrespect but seems a no brainer to me after all you've sought advice on and tried... The parts place has the better warranty. If it don't work you exchange it until you get one that works if that really is the issue.
easy for me to sit here and spend your money huh? lol To their credit, the real good advice has come from guys other than me in your recent threads, but i have been following and hope for the good news that the van is running well for you
UPDATE: So I put in the A1 CARDONE PCM #79-8267 this morning. I ran the van up and down my parking garage for about 10 mins with no problems. I was nervous but I ran it down the street and back maybe 6 times (total 2 miles) and it seems like it is running normal. The key dance still gives code 37 but that is another issue in itself I guess. Everything seems good at the moment. Once it stops raining I'm going to take her out on the highway and run at least 10 miles and see what happens. I'll keep you guys updated! Thanks again for everyone's help!
