The FNG
#21
The one ton trucks use a variety of adapter on the front as well, so it can use the same wheels/tires all the way around. If your front is 8 lug as well, (which it should be...) might wanna look into that, just for convenience sake.
Yes the front is 8 lug.
#22
Ok so you're saying I can get adapters so the front and rear wheels are the same? I just need to score 2 more wheels for the front then. Maybe off a dually pickup?
Attachment 127807
Attachment 127807
#23
Attachment 127807
Attachment 127807
Front wheels off an SRW 1 ton truck will be different than off a dually truck. SRW are fairly flat. The dual wheel trucks have the front wheels off set out a bit so all the wheels are the same. The inner wheel in back goes in deep and the front will match that.
#24
