Heat and radiator question.
Old Sep 26, 2025 | 09:20 PM
Frank_S1975's Avatar
Frank_S1975
Default Heat and radiator question.
I have recently purchased a converted 2000 ram 3500 van. The van has no cabin heat and the temperature gauge has never reached 210. The radiator was about 2 inches empty and the overflow tank was empty. The coolant inside the radiator other than being low is a clear yellow and smells fresh. I was thinking the thermostat was stuck open until I saw the low coolant. Now I wonder if the coolant wasn't changed recently but never properly had the air burped out. Or if it is the thermostat or both. The family blows like a champ and I can hear the flapper flap when I turn the temp **** as well. Any thoughts?
Frank
Old Sep 27, 2025 | 09:27 AM
Are the hoses properly routed? What coolant is that supposed to have? I thought it was the green stuff..... Mixing coolants can lead to plugged up systems...... Low coolant would tend to make the van run hotter..... I would pull the thermostat, and see if there is one.....
Old Sep 28, 2025 | 09:54 AM
Moparite's Avatar
Moparite
IF it does have one see what temp it is, May be lower than the stock one. You may want to drill a small hole in it if it doesn't have one. Check out this thread (post 14).
Old Sep 29, 2025 | 01:24 PM
Frank_S1975
Had the shop look at it. They think the issue was from low coolant and a bad blend door as well.
Old Sep 29, 2025 | 05:42 PM
Frank_S1975
Frank
Well I have heat when I move the blend door. Now to search down an actuator and arm.
Old Sep 29, 2025 | 07:08 PM
Frank_S1975
One of the gears inside was broken into 2 pieces. Apparently it is easier to remove than to find a replacement. Still searching
Old Sep 30, 2025 | 06:16 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
It is discontinued; you'll need to get an aftermarket one.
Old Sep 30, 2025 | 06:27 AM
Frank_S1975
The aftermarket ones I am finding say they fit both the ram truck and van but when I check vehicle fit it says it don't fit the van just pickup.
Old Sep 30, 2025 | 10:02 AM
jeffersonracing's Avatar
jeffersonracing
3d printing is getting really popular and that gear could be replicated.
Old Sep 30, 2025 | 03:06 PM
Los_Control's Avatar
Los_Control
Any way to just connect a cable to it and work it manually?
