Trans, Differential, or ?
Old Feb 24, 2026 | 01:54 PM
maelduin's Avatar
maelduin
Default Trans, Differential, or ?
Since I've had this 2002 van for a year and a half I have felt and heard a clunk when it feels like a loss of power and then the clunk as it catches into gear (?) for a split second. I have had the transmission replaced with a rebuilt (it was starting to slip), but still have the same issue which is very intermittent. Sometimes happens a few times within a minute or so, and often doesn't happen on some trips. Seems more often during a climb and has happened anywhere from 30 to 60 MPH.
Any ideas would be greatly appreciated. It's a 3500 with about 130k miles, the 5.2 liter V8. It was a government van, probably bought at auction before I purchased it.
Old Feb 24, 2026 | 10:15 PM
wheily's Avatar
wheily
if engine pops out intake it could sound like a knock with a loss of power than recover ..but tHats just a gess
Old Feb 25, 2026 | 02:49 PM
maelduin's Avatar
maelduin
Thanks for replying Wheily.
I don't know what you mean by engine popping out intake, but I can feel the whole van shudder when it happens, but very fast.
Old Feb 25, 2026 | 08:44 PM
TCC shudder maybe?
Old Feb 27, 2026 | 03:34 PM
maelduin's Avatar
maelduin
Thanks for the reply HeyYou. The clunk makes the van feel as though it goes in and out of gear very fast and lasts just a split second, even after the rebuild was done. I'm wondering if it might be something electrical or whether it might be coming from some differential problem.
Old Feb 27, 2026 | 03:51 PM
When the trans was rebuilt, did they replace the electronic in the trans? Toque converter?
Old Mar 1, 2026 | 12:43 PM
maelduin's Avatar
maelduin
It was swapped out for another rebuild in November 2024. I don't know if any electrical part was changed other than what might be needed when replacing the transmission. Isn't there a solenoid switch involved with the timing of the gears shifting? Often when the hard clunk happens the van's already in 4th gear, so not really shifting into a higher gear, doing about 55-60 mph. Do you think it might be some electrical control that was not changed? Thanks for your help.
Old Mar 1, 2026 | 08:26 PM
If they changed the entire trans, then likely they changed all the electronics as well. Torque converter is still open to question though.
46RE trans more'n likely.... So, 1-2, 2-3 are actual gear shifts, electronically controlled, of course. Once in third gear, should get a slight RPM drop when TCC locks, then, when above 42mph, it'll shift into O/D, which should be a pretty significant RPM drop. after that, there is nothing else to happen.....
Old Mar 3, 2026 | 01:08 PM
maelduin's Avatar
maelduin
Thanks HeyYou! Every little bit helps.
Old Mar 3, 2026 | 07:21 PM
ElkCon's Avatar
ElkCon
are you sure it isnt like a total engine shutdown for a split second? or the alternator grounding out? something werid like that?
Ill ask the other guys help here - but wouldnt a CPS/Distrub pickup that abends for a second make it feel like the trans slipped?
