Old Aug 7, 2015, 02:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exhaust and Intake System
Print Wikipost
DIY How to clean the IAC
Old Feb 29, 2016 | 08:04 AM
  #81
a1mfw's Avatar
a1mfw
Cleaned it once on my van. Had to replace it later on due to vehicle not wanting to run. Don't think it is something you are going to need to worry about cleaning frequently. Just spend an extra 15 minutes taking it out to clean when you are cleaning your throttle body.
Old Mar 7, 2016 | 08:17 PM
  #82
stev's Avatar
stev
Originally Posted by pickyourking
Is there anyway to get a these pictures re-uploaded?
This original thread I started with the pixs no longer works showing the pix after the forum upgrade.
I did upload this How To Clean The IAC on two other Dodge forums. One of them is the Allpar site under the forums. I can't list the other since it competes with this one.
Also, if anyone has a rusty pintle IAC, just replace it. It's not worth having the rust re-appear and stick the idle closed. You will be stranded in no time.
Old Sep 24, 2016 | 10:49 AM
  #83
David DeBord's Avatar
David DeBord
Stev,
Could I get a link for that site?
I'm having many of the same problems listed in this thread, & I'm thinking that I've got to call a Priest & have him Exorcise my work Van.
Old Sep 24, 2016 | 02:18 PM
  #84
alloro's Avatar
alloro
Van & CUV Section Moderator
If you're referring to the DT site then that ones doesn't display the images either.
Old Sep 25, 2016 | 07:08 AM
  #85
David DeBord
Stev, "If" you still have that data, ..... Could you E-mail it to me?
Old Oct 2, 2016 | 06:00 PM
  #86
kbubbs's Avatar
kbubbs
Thanks a lot for this, I'll give it a go. Do you know anywhere on the bed that still has the photos attached to the description?
Old Aug 9, 2017 | 10:42 PM
  #87
happyhourtx's Avatar
happyhourtx
such a bummer. the pics dont load. sure would be useful to me if they did! thanks for the walk through though. i will figure it out!!
Old Nov 1, 2024 | 08:33 PM
  #88
Critt's Avatar
Critt
I don't see the pictures. Did anyone find a fix for that?
Old Nov 1, 2024 | 09:02 PM
  #89
Probably not there anymore... so, there is unlikely to be a fix.... Considering the age of this thread, and the fact the OP hasn't been here in 8 years....... There should be other threads of this nature around as well, probably in the 2nd gen Ram Truck section, as they used the same engines.
