Misfire of the 4th cylinder
Old 06-04-2011, 01:43 PM
elizabethopal's Avatar
elizabethopal
elizabethopal is offline
Default Misfire of the 4th cylinder
I have a 2006 Dodge Stratus, 2.4L DOHC. My check engine light came on, I had the code read & it was "P3104" which is a 4th cylinder misfire. I've already replaced the plugs & wires, and the coil pack. And it's still misfiring, I had the code cleared when I replaced everything, it ran okay for about a day & it started misfiring again. Does anyone have any ideas as to what it could be and how to fix this? Thank you!
Old 06-04-2011, 07:13 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Welcome to DF
Remove all the spark plugs and perform a compression test and post.
Old 06-09-2011, 09:02 AM
elizabethopal
The 4th cylinder is at 90 and all of the others are at 180. Thank you!
Old 10-22-2012, 03:29 PM
Dan0's Avatar
Dan0
Dan0 is offline
Is this common? I have a 2003 Stratus with the 2.4L DOHC engine... P0304 (4th cylinder misfire).
Old 10-22-2012, 05:52 PM
Dan0's Avatar
Dan0
Dan0 is offline
Mine are all at 150 except #4... which is at about 80. (The engine is warm but not at operating temp.)
So... what did you do... fix it or scrap it?
After I did a wet test... the pressure went up, so it's the cylinder... not the valves.
Thanks
Quick Reply: Misfire of the 4th cylinder
