2006 Stratus SXT - Air Conditioning Issue
Old Jul 7, 2011 | 11:25 PM
darraghhogan's Avatar
darraghhogan
Default 2006 Stratus SXT - Air Conditioning Issue
Hello,
I have a question regarding my 2006 Dodge Stratus SXT. It appears that my air conditioning system will only work when the fan is turned up all the way. It doesn't matter what function I'm trying to use (A/C, defrost, etc). Any idea as to what might cause this? Thanks for your help.
Darragh
Old Jul 8, 2011 | 12:10 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Have you had any repairs done on the a/c system?
Old Jul 20, 2011 | 02:38 PM
sbeyer123's Avatar
sbeyer123
i have a 2005 dodge stratus SXT and my heating/air conditioning only works on level 3 and 4. This just started 2 days ago. I have not had any service done except an oil change 2 months ago
Old Jul 20, 2011 | 09:08 PM
Bio-Diesel's Avatar
Bio-Diesel
I am assuming that you mean the heater-A/C blower motor only cuts on when you turn the dash switch to the high position in which case you need to replace the blower motor resistor. This is a common problem with these cars and my 04 did the same thing.
Old Jul 21, 2011 | 12:09 PM
sbeyer123's Avatar
sbeyer123
the blower only works on level 3 and 4. 1 and 2 produce no heat/air conditioning. do you know how much a blower motor resistor would cost to have installed?
Old Jul 21, 2011 | 12:10 PM
sbeyer123's Avatar
sbeyer123
also, thanks for your response Bio-Disel!!!
Old Jul 21, 2011 | 12:35 PM
darraghhogan
Turned out to be the blower motor resistor. It was only $17 from my local Dodge dealership, and it was easy to install. Thanks everyone!
Old Jul 21, 2011 | 12:36 PM
darraghhogan
Thanks Bio-Diesel!
Old Jul 21, 2011 | 05:04 PM
Bio-Diesel's Avatar
Bio-Diesel
Your welcome, glad you got it fixed.
