2002 Dodge Status Sedan 2.7L automatic - #8 starter fuse blows
Old 03-22-2013, 04:38 PM
markylew's Avatar
markylew
markylew is offline
For the following test "Key in OFF position
Starter relay removed
connect test light to battery +
make contact with relay socket terminal that feeds the S post on the stater.” The test light lit up. I will redo to verify I probed correct socket.
After that I wanted to verify I was probing correct relay socket terminal (#87 of relay). So I put relay back in. With test light clip connected to ground, I probed the disconnected trigger wire and turned ignition to start, light lit and I measured 11.9V as well. Fuse didn’t blow since trigger wire not connected to starter. Yes, trigger wire is a brown wire. I thought ohm’ing out from wire clip to relay socket would confirm I was on correct socket.
All the wires are wrapped in original factory wrap. I had checked under fuse/relay box and it’s really clean, wires look good.
I have Haynes manual.
Old 03-22-2013, 05:26 PM
D Ryan's Avatar
D Ryan
D Ryan is offline
To isolate circuit disconnect small wire for test, not sure what those simbols are you see inside starter!
This is not your car but theory the same, it shows wires shorted to ground, also shows wires shorted to other wires and that's not good at all. It could get the computer! There are 3 videos this is the last.
Old 03-23-2013, 03:39 PM
D Ryan's Avatar
D Ryan
D Ryan is offline
This would be a cool tool for where your at!
Old 03-23-2013, 05:02 PM
markylew's Avatar
markylew
markylew is offline
Yep, I've seen this video and the tool looks so primitive but very effective!
Old 03-24-2013, 10:26 AM
D Ryan's Avatar
D Ryan
D Ryan is offline
I've been making one! That directional tool is a compass! Found this ! enjoy!
Tech
Old 03-24-2013, 06:06 PM
markylew's Avatar
markylew
markylew is offline
I redid the following test.
The test light lit up. I removed trigger wire to S post and light turned off so I know I was on the correct relay socket.
Great find on that tool!
Old 03-24-2013, 06:42 PM
D Ryan's Avatar
D Ryan
D Ryan is offline
Good!
New test:
"Key in ON position
connect test light to battery - NEG
Done
Did you ever find the diagrams for eng controls?
Quick Reply: 2002 Dodge Status Sedan 2.7L automatic - #8 starter fuse blows
