2.4L timing belts
Old Nov 27, 2005 | 05:59 AM
fender]['s Avatar
fender][
Default 2.4L timing belts
Hi all
I have a questune about my 1997 2.4L 4cyl engine in my stratus
is this engine the type that when the timing belt breaks it will smash the pistons into the valves? ( interference head )
and secondly is a timing belt difficult to change in these engines?
thanks for the help
Damien
Old Nov 27, 2005 | 06:44 PM
Ice_Man_67's Avatar
Ice_Man_67
Default RE: 2.4L timing belts
I'm gonna say yes, it's a big job. Judging from the haynes manual you gotta remove the engine support and so on.......
Old Nov 28, 2005 | 04:29 PM
highrevr/tflea's Avatar
highrevr/tflea
no the 2.4 isnt nearly as destructive as the 2.0 my buddies timing broke twice on his 2.4 and just got a new belt and runs like new....
Old Dec 5, 2005 | 02:31 AM
CptGloval's Avatar
CptGloval
i have a 2.4 and have replaced mine twice. It is a ZERO clearence engine, so be very very careful you could damage it easily. Yes, it's kinda hard to change. The second time i brought it into a shop because i felt the extra money was worth not dealing with the time it took with my simple garage tools.
Old Dec 5, 2005 | 11:54 PM
brandoncrone's Avatar
brandoncrone
Its not really an interference engine, it can be depending on the conditions. Ive replaced hundreds of 2.4 belts, about a quarter of them broken and the valves never get hit.
Old Dec 12, 2005 | 01:54 AM
prowlertech01's Avatar
prowlertech01
yes the 2.4L engine is an interference engine, if the car is running under load and the belt brakes the valves usually bend...i have seen several instances where the customer has been ideling when the belt goes and not effect the valves,but i have also seen a cold nostart condition,when the car drove fine when turned off the prior night and then tried to start in the am and the belt brakes andbent valves as well.be aware that chrysler has a new desinged belt tensioner again and requires a new inner timing cover set as well...comes as a kiti have done several belt replacements and if you arent sure it is always beneficial to have a knowledgeable tech perform the repairs...
Old Dec 12, 2005 | 02:30 PM
fender]['s Avatar
fender][
took it to a dealer,
about this new tensioner does that have to be replaced on this timeing belt change or is it a "change if needed item "
cause they never said anything about changing the tensioner at the chrysler dealer.
but i dont trust the dealership and i dont want it to eat away my new timing belt.
cheers
Damien
Old Aug 6, 2013 | 06:27 PM
PaulHoad's Avatar
PaulHoad
Default 05 dodge stratus
how do i keep my cams lined up too time it every time its one notch off?
