They're HPD Cooldown rims. They're in my price range and according to the HPD website, these will fit an '02 stratus sedan, will they fit my R/T? These are the specs;
17x7.50in
5x100mm
offset = 42
i think the R/T bolt pattern is 5x114mm, they wont fit. easiest way to find rims is to see if they will fit the 02 Eclipse GT, same bolt pattern, same chassis as the R/T
i just bought me an 04 stratus r/t coupe last nite and already found some good stuff. esp. for fitting rims. http://www.wheelmax.com/packages.asp u just input make, model, year and they make sure that their rims fit your car.
The Stratus R/T bolt pattern is 5x114.3 and and those wheels will not work. The Stratus sedan's use the 5x100 bolt pattern.
If you want some good, cheap wheel & tire sets.....I recommend you hit up www.edgeracing.com I bought my wheels from them with tires for $752 delivered to my house...
