K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Blow by?
Old Aug 23, 2004 | 03:51 PM
rareram's Avatar
rareram
Default Blow by?
A few weeks ago while driving about 70 mph, my 2.2 started leaking oil all over the exhaust. Took it to a shop and they say the rings are shot, allowing the pressure into the oilpan, blowing out the gasket. Since it runs strong and doesn't burn oil, I question this. Anyone have any knowledge of this? Thanks.
Old Aug 24, 2004 | 12:54 AM
87Indy500's Avatar
87Indy500
Default RE: Blow by?
Blowing out what gaskets??
I don't think that the rings are the culprit.
Old Aug 24, 2004 | 05:23 AM
71RoadRunner's Avatar
71RoadRunner
I agree, I don't think that that is the case either. If your rings were that bad you would have noticed a huge amount of blue smoke as it would burn the oil in the combustion chamber. Not only this, but it would have shown a very noticeable drop in power. It could still be a head gasket, but not your typical blown head gasket where it leaks from the combustion chamber. It could be just a leak from an oil passage from the head gasket. It could also be from a bad head gasket or possibly a cracked head. The only other thing that I can think of is a bad PCV adapter, the rubber elbow that connects the PCV valve to the valve cover. Other than that, I cannot think of anything else that it may be right now. How much oil did you loose and did you notice a drop in oil pressure when this happened?
Old Aug 26, 2004 | 03:50 PM
rareram's Avatar
rareram
I had blue smoke, but it looked like it was splatter on the exhaust. The underside was covered with oil. I changed the VC gasket and the PVC was clogged so I changed that. I'm thinking oilpan gasket.
Old Aug 27, 2004 | 03:55 AM
GTCandGTSturbo's Avatar
GTCandGTSturbo
The PCV (not PVC) could exaggerate your blowby if it was clogged. Did that fix it? The VC gaskets allways go bad - switch to a 89+ valve cover if the problem persists.
Rings would be a problem over time, not all of a sudden, unless it just was leaking for awhile and you didnt notice.
Old Aug 27, 2004 | 03:19 PM
rareram's Avatar
rareram
I haven't had the car that long. This happened on my 1st long trip since driving it from PA to VA. I replaced the VC gasket and PCV and then took in on the highway and it was still doing it. I guess the oil pan gasket is next.
Old Mar 18, 2005 | 02:49 PM
matt_guiver's Avatar
matt_guiver
the shop guys are right. duhhh. GET A CHEVY AND YOU WONT HAVE THESE PROBLEMS
Old Mar 18, 2005 | 03:05 PM
GTCandGTSturbo
Talk about digging up an OLD thread...
Get a Chevy and you may have different problems, but with a car that old you're going to have them.
Oh, and what is your quals matt_guiver to be making that statement? You just sound like a troll with that comment.
Old Mar 18, 2005 | 03:53 PM
87Indy500's Avatar
87Indy500
ORIGINAL: matt_guiver
Shop guys [sm=loser.gif]
Old Mar 20, 2005 | 10:28 PM
casper's Avatar
casper
Why would you dig up an old thread just to start. If you don't like dodges goto another site!!!!!!!!!!!
