stock evo vs stock srt-4
Old Sep 18, 2004 | 07:06 PM
  #31
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: stock evo vs stock srt-4
Is it wheelspin or what?
Old Sep 19, 2004 | 05:33 AM
  #32
badsrt4's Avatar
badsrt4
i might not be the best one to talk about this.. but what i was told to do was not to wet the tires, make a short burn out, rev it up to 2k rpm's and let go the clutch after the second yellow light., but my problem is that after i get out i slam the gas, i dont know why but i do it, thats probably why my times are not so good.[&o][&o] , i would like to know what am i doing wrong, or what alse can i do to improve my times, also once i get the 2nd stage installed are the launches gonna be harder to make???
Old Sep 19, 2004 | 08:25 AM
  #33
71RoadRunner's Avatar
71RoadRunner
Twice was from wheelspin, once was from babying the **** out of it and the other time was just too little throttle too long. Two times I went too far in first to where the boost fell off before I shifted, that didn't help matters. I never heated or lowered the tire pressures either, I have heard that it will make a difference since they are a fairly soft race-like compound tire. Most conventional radials bite better with higher tire pressures and no burn out. Next time I will do it right and make more passes.
Old Sep 21, 2004 | 05:32 AM
  #34
Barneydriver's Avatar
Barneydriver
in my experience, tire pressure does make a difference- i run a solid .2 better w/ about 25 psi on the stock setup than w/ regular pressures (i run 45 psi). the burnout, however, has not ever done anything for my times, so i stopped wasting my tires. just getting the heat of a couple runs in them seems to be plenty.
