boosting in neutral...help....trouble...aaaahhhh
Old Apr 14, 2005 | 11:46 PM
04srt4lvr's Avatar
04srt4lvr
Default boosting in neutral...help....trouble...aaaahhhh
boosting in neutral.........what the #$%@ ! agp wastegate... just started after i installed a block off plate and a hks bov and pressure pipe . bov works fine .
Old Apr 15, 2005 | 02:51 AM
PSI Chick's Avatar
PSI Chick
Default RE: boosting in neutral...help....trouble...aaaahhhh
what do you mean boosting in neutral? that's not really possible. please describe exactly what the car is doing and when it's doing it.
Old Apr 15, 2005 | 11:25 AM
04srt4lvr's Avatar
04srt4lvr
in neutral whe i rev it up the boost gauge goes past 0 not quite surehow far past maybe 5psi
Old Apr 15, 2005 | 12:26 PM
CSXT802's Avatar
CSXT802
Whats wrong with that?
Old Apr 15, 2005 | 12:29 PM
PSI Chick's Avatar
PSI Chick
all that the gauge is showing is that the turbo is spooling, not that you're actually making boost. i can get my boost gauge up to like 15psi in neutral, but that doesn't mean that the turbo is actually pushing that. you can not physically make boost unless the engine/turbo is under load, which it's not in neutral.
Old Apr 15, 2005 | 12:43 PM
CSXT802's Avatar
CSXT802
PSI chick, at what rpm do you make your max boost ( psi )?
Old Apr 15, 2005 | 01:01 PM
PSI Chick's Avatar
PSI Chick
on my current set up i'm not sure, i have not been to the dyno yet. on my previous one (s2), i showed max boost of 19psi@5600rpms. however, if you look at the dyno you can see that i basically ran out of turbo right around there as well. part of it is the stage ecu's that pull insane timing on the dyno....
Old Apr 15, 2005 | 01:54 PM
04srt4lvr's Avatar
04srt4lvr
its never registered boost before i put my new hks bov and hard pipe on there and now when i am in gear it s boosting way past 20 psi
Old Apr 15, 2005 | 09:38 PM
71RoadRunner's Avatar
71RoadRunner
It sounds to me like you need to readjust your wastegate. This will bring your boost back down below 20 psi where it needs to be. Mine will register boost if I rev it up in neutral as well, the harder you rev it the more it will show. If you rev it fairly lightly it should only go up to zero, but if your revving it hard it's going to go above zero.
Old Apr 16, 2005 | 11:44 AM
black4's Avatar
black4
hey psi what all did you have to do to get it to pull 19 psi on stage 2 setup and how far does it hold peak boost in the power band. thanx fo your time and is it safe.
