$2000
RE: $2000
ORIGINAL: dolem20
2004 SRT-4 with mopar exhaust. I have $2000 what can i buy to get my car in the low 13's and my car be drivable. I was thinking about getting stage 2 but i was told there are better options out there. Thanks for anyone info?
Sounds like my budget and I want to keep it all "Mopar" in mods. I'll be adding a Stage 2 without toys and the other stuff in my signature. Just adding the BOV conversion for the sound. Probably will also add a red powdercoated valve cover (just because I like the way it looks) + ignition upgrade and I should be in way under $2000.
RE: $2000
Not trying to argue here, but I have a question: If someone almost never uses the "high octane" mode...are the "toys" really worth it? On regular octane mode, I've seen graphs that nearly put down the same HP and TQ numbers for toys VS no toys. Wouldn't the extra money spent on the "toys" be better used on a larger cooler? Or not? For me, a larger cooler would be used 100% of the time - High octane mode would be used about 2% of the time.
ORIGINAL: Nicky B
Get a stage 2 with the toys, cold-air intake, exhaust, and with high octane mode on you can hit the low 13's with good tires.
RE: $2000
i got 13.2 with just wga and fmic on strret tires.thats about 700.00 to gether so with 2,000 you should buy intake,fuel pump,wga,ebc,stg1,and exhaust oh and some nice mm for wheel hop.If i can get a 13.2 on street tires and no nos you should be able to get a 12.9-13.flat with this stuff.I think stg2 is way to much for the mods and from what i herd its not all that.
RE: $2000
ORIGINAL: MEandmySRT
ORIGINAL: Nicky B
Well what other modd is there when alls you need to do is press a button to gain 20HP without increaseing boost levels. And if you get a stage 3 you could gain 40HP in High Octane Mode.
Trending Topics
RE: $2000
ORIGINAL: Nicky B
RE: $2000
ORIGINAL: Nicky B
ORIGINAL: Nicky B
Because, like I said, I'd never use the "high octane" mode. You need at least 100 octane fuel to use the H.O. mode, yes? And since I won't ever have H.O. fuel in my car when I'm making boost...except for maybe 1% or 2% of the time, it would be a waste of money for me. But I could use the larger cooler all the time. Anybody know how much HP gain a "Monster" cooler would add to a Stage 2 with intake and exhaust mods? Thanks.
RE: $2000
ORIGINAL: Nicky B
ORIGINAL: Nicky B
