Speed Limiter question
Old Jul 18, 2004 | 07:52 AM
05SRT4's Avatar
05SRT4
Default Speed Limiter question
I know the speed limit on these cars is limtied to 148mph by the computer but does the stage 1 or stage 2 computers change this to a higher limit or remove all together like most of chips or after-market computers(on other cars)?????
Old Jul 18, 2004 | 10:11 AM
fortywillys's Avatar
fortywillys
Default RE: Speed Limiter question
I could be mistaken but other than the rev limiter a don't think there's a top speed limiter. Sense most vehicle's with top speed limiter's usually cut out above the top speed (by killing gas or timing) . And to me it would be stupid to run two limiter's sense the rev limiter can do both job's. Unless they run 2 limiter's sense it's a stick. But a do know the stage 1-3 computer's raise the rev limiter. Any one else know any more?
Old Jul 18, 2004 | 11:27 AM
71RoadRunner's Avatar
71RoadRunner
Yes, they do indeed have a speed limiter. The factory says it is set at 148 MPH, but it appears that people who challenge this limiter reach around 153-155 MPH before the limiter kicks in. I believe that the Stage upgrade computers eliminate these speed limiters and raises the rev limiter.[sm=smiley2.gif]
Old Jul 18, 2004 | 11:47 AM
glhs837's Avatar
glhs837
No limiter, many folks in have reported speeds in excess of 155. Roach, SRT USAF out your way was the first, with a GPS verified 157, I think. Stage 1 does not change the rev limiter, Stage 2 raises the redline from 6250 to 6500.
Old Jul 18, 2004 | 01:06 PM
71RoadRunner
Is that without any of the PCM upgrades? Dodges' site specifically says that it is limited to 148 MPH, but I know that some little things can change that and I've heard that newer cars are built with the speedo to read a few MPH's more than what they are actually going because of our lead feet in this country.[sm=smiley3.gif][sm=smiley36.gif]
Old Jul 18, 2004 | 01:33 PM
byebye's Avatar
byebye
Has anyone seen the 80 to 160mph video on the net? That guy pegs it out to 160 so it's not impossible. I have the video I don't remember where I got it. Probably srtforums.com. I also thought it was drag limited to 155 according to car and driver and other car magazines.
Kris H.
Old Jul 18, 2004 | 04:28 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I have that video clip as well. He does indeed peg the speedo needle at 160...and then backs off very quickly!!![&:]
Old Jul 18, 2004 | 04:37 PM
roachnigga's Avatar
roachnigga
I would like to see it... which site!!
BEFORE THE S2 I PUSH HER AT 143 MPH; NOW THE HIGHEST IVE GOTTEN HER WAS 153 @ 5745 RPM'S ON THE AUTOBAHN.[8D]
Old Jul 18, 2004 | 05:52 PM
glhs837's Avatar
glhs837
http://srtforums.com/forums/showthre...hlight=160+vid
Good discussion here, maybe links to vids.
Roach, a few points to consider, headwinds, at those speeds, it could indeed be a factor, also, is your rubbery scraper installed? Also, how many miles did you have when you went for the stock run? We are pretty sure the cars take a while to make full power.
Old Jul 18, 2004 | 06:58 PM
roachnigga's Avatar
roachnigga
Headwinds: Tailwind when i had that speed (153) Tailwinds, for those dont know, is when winds are comin' from behind pushing you foward.
Rubber Scraper?: Not sure what it is/ probably not
Miles: I had over 1800 miles before i pushed her to 143 mph.
does it help on this discussion
ORIGINAL: glhs837
