map sensor
Old Jan 25, 2007 | 10:47 AM
redevil's Avatar
redevil
Default map sensor
I put on a 255 fuel pump a couple days ago.I'm holding 15 psi in 2nd gear and all the rest is about 20psi.But I can't WOT shift because I get huge fuelcuts.Would it help if I get a s2 or s3 map sensor?I have a map clamp sitting at home but not too sure if I wanna go that way.
Old Jan 25, 2007 | 11:33 AM
MChat's Avatar
MChat
Default RE: map sensor
You don't want to just throw a S2 MAP sensor on there. In order to run the S2 MAP you need a way of modifying the MAP signal, aka a "Piggy Back" fuel computer like the D-Tec.
Your best bet would be to use the MAP-Clamp you have, or get a piggy-back fuel computer.
Old Jan 25, 2007 | 11:41 AM
redevil's Avatar
redevil
yeah but I've heard map clams are not very good, well in the long run.I'm planning on upgrading to a t3/t04 ball bearing 50 trim with supporting mods(dtec,cams,fmic and all that good stuff), maybe by september i 'll be ready.You think running with the map clamp for a few months would be ok?
Old Jan 25, 2007 | 12:04 PM
prpaster's Avatar
prpaster
If you get it tuned in right it should be fine. There are many people running map clamps without any problems
Old Jan 25, 2007 | 12:14 PM
redevil's Avatar
redevil
yeah I guess I'll go to a shop this friday and get it tuned.thanks guys.Hey Mchat you and psichick still fighting?
Old Jan 25, 2007 | 12:58 PM
MChat's Avatar
MChat
ORIGINAL: redevil
I have no idea.
I don't even knowwhy she started attacking me on public forums in the first place.
Old Jan 25, 2007 | 01:24 PM
04blksrt's Avatar
04blksrt
DAMN ED!!!! why even bring that back up!
Old Jan 25, 2007 | 02:39 PM
PSI Chick's Avatar
PSI Chick
because i'm tired of your arrogant attitude put some numbers up then get cocky.
Old Jan 25, 2007 | 03:14 PM
blacksrtinAZ's Avatar
blacksrtinAZ
ORIGINAL: PSI Chick
His time is still faster then yours
R/T: .008
60': 1.768
330': 4.939
1/8: 7.434 (mph not listed)
1000': 9.523
1/4: 11.372@126.989[/align][/align][/align]So what's your point PSIChick? E-thugs can be female. or are they E-beatches?[/align]
Old Jan 25, 2007 | 03:26 PM
redevil's Avatar
redevil
omg!!!!!!!!not again.......let's get back to the original thread people
