front end grinding after bump
hi all, i'm new to DF. i,ve been on site before and got some usefull info, hopin' someone might be able to point me in right direction. I have 3rd gen
07 ram 1500 4x that i'm getting a grinding noise in front end after hitting ANY kind of bump. is there a common issue with this or do i just need to tear into it?
Welcome to the forum!
I'm sorry to learn of the grind noise you're experiencing. When did you first notice the noise? Did it appear suddenly, or was it heard first when going over larger bumps and became more frequent?
Did the wheel bearings fix this issue? I just developed a grinding noise in my front end. 4x4 works fine, but over bumps you can hear grinding occur. I thought it was my actuator, but my 4x4 goes in and out fine. I feel like it could be a vacuum issue and my shafts aren’t disengaging all the way causing a grinding noise. Any help is appreciated!
-Mitch (07 Ram)
-Mitch (07 Ram)
