00 1500 tranny removal cant get it out
Old 07-05-2017, 05:30 PM
comet424's Avatar
comet424
comet424 is offline
Default 00 1500 tranny removal cant get it out
I working on a 2000 1500 ram and I cant get the tranny out
I have done every thing I pulled 4 bolts off the back of tranny and the 2 bolts on the front and I cant separate it.. also taken those 4 bolts off the flywheel.. I tied come a long to the tranny and to my backhoe and she still wont come off... whats holding it I see 2 pins I guess do they punch out how you get those out
Old 07-05-2017, 05:57 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
I believe there are a couple of bolts that hold the transmission from the other side. Did you pull the starter? Be sure to pull the starter and check for the bolts that go from the engine into the transmission.
Old 07-05-2017, 06:11 PM
comet424's Avatar
comet424
comet424 is offline
ya that's what I ment by the 2 bolts from the front one was above the starter and the opposite side... but she wont slide off with using the come a long..... I seen 1 locating pin and I felt for it on the side above starter but I cant get them out if they hammer out I tried heating I tried air chisle to shake nothing working
so wanted to know how many botls hold this thing on
Old 07-05-2017, 08:17 PM
comet424's Avatar
comet424
comet424 is offline
here is video yes I know crap but best I could do laying under truck
I have the strap tied to my backhoe giving tension on the tranny to pull it out...
you can see 2 bolts removed on the one side and I removed 2 bolts on the right side on the back,,, and then you see in video bolt removed above starter and the one on the other side is removed too
total 6 bolts removed
cant split it
Old 07-05-2017, 08:53 PM
AtomicDog's Avatar
AtomicDog
Is the starter removed also? It has to come off, If I recall correctly. You likely still have a bolt or two left.
Old 07-05-2017, 09:04 PM
Moparite's Avatar
Moparite
Moparite is offline
There is a total of 7 (seven) bolts just that hold the bell housing to the back of the block! I think you missed a few.
Old 07-05-2017, 09:27 PM
comet424's Avatar
comet424
comet424 is offline
in the video you see the fly wheel and the starter removed as I mentioned those are the 2 front bolts.
as for 7 bolts so I have removed six ... 4 in the back where would that one last be
I removed the 2 you see in the video
and the other side was the Dip Stick bolt and the one below it... where would the other bolt be
its awkard to see it..
is there a picture where it shows the bolt holes so I can see
Old 07-05-2017, 09:44 PM
AtomicDog's Avatar
AtomicDog
Thanks for clarifying that the starter is removed - I could not see that from the video. There is another bolt on the front near the starter - did you remove it? That one tripped me up before.
I suspect it is at the top of the bellhousing, cleverly concealed somewhere. Might need a mirror to see it....
Old 07-05-2017, 10:09 PM
Moparite's Avatar
Moparite
Moparite is offline
There is one directly on top in the middle and the others are evenly spaced apart.
