Multiple problems
Old 07-18-2017, 07:55 PM
Kimberly Collins's Avatar
Kimberly Collins
Kimberly Collins is offline
Default Multiple problems
Looking for multiple opinions here. For the past few years every summer I have to change my front bank o2 sensors. Only once I've changed my rear O2 sensors. I own a Dodge ram 1500 Quad cab 5.7 hemi and suddenly I'm having more problems than ever. I have 133,000 miles on it. On a hot day 6 weeks ago my tachometer dropped, CEL came on, check gauges light, lights flickering. Turned out to be crank shaft position sensor. Then cylinder 3 misfire. Replaced spark plugs cuz it was time anyway and had mechanic put new crank shaft position sensor. All well. 3 weeks later, another really hot day, code p0052. Replaced 2/1 o2 sensor. Code cleared until next day. Next day tachometer drops again, CEL on, and blinking. Mechanic said he thinks it's my PCM so he knew a guy and had one put in, got truck back, CEL came on, saying crank shaft position sensor. Had old computer put back in. Mechanic says to replace cam sensor. Given he's far away and I'm not a mechanic, I took it up the street to auto max. They have multiple codes. They said I have bad ECM, cranks shaft sensor, alternator, battery, and cylinder 1 misfire.
What the heck?!!!!any suggestions? Mechanic says to replace the cam sensor and go from there. I won't be having automax fix it cuz they are $100/hour. My pockets are not deep. Thanks Dodge forum!
Old 07-18-2017, 11:19 PM
p38251's Avatar
p38251
p38251 is offline
Did they tell you what the codes are?
Old 07-19-2017, 09:39 AM
I would go to the nearest parts store, and have them read the codes for you.
Old 07-19-2017, 07:29 PM
Kimberly Collins
P0339, p0300
Old 07-19-2017, 07:32 PM
Kimberly Collins
I'm going to put a cam sensor in, disconnect the battery, then go to les schwab and have them test my alternator and go from there. I will let you know how it goes cuz I might need ideas. Funny how the shop said just a few days ago that my truck "is running beautifully" and now there's all these issues.
Old 07-19-2017, 09:38 PM
p38251's Avatar
p38251
p38251 is offline
P0300 is multiple miss fire. When was it's last tune up? PCV? Throttle body cleaning? Injector cleaning?
Old 07-22-2017, 06:02 PM
aliaj00@gmail.com's Avatar
aliaj00@gmail.com
aliaj00@gmail.com is offline
He has a wiring issue there. look the cables for shorts or dented ones most probably if the instruments are flickering you have a short somewhere. or check the grounding if it is not making good contact them is the same as a short. keep it simple check ground and cables. the wiring can be a b...ch.
regards,
Tim
Old 07-26-2017, 08:48 PM
Kimberly Collins
Default The codes
Ok the codes are p0300, 02302, p0335, p0339, p0052
I just replaced the cam sensor and the 02 sensor for bank 2 sensor 1. Crankshaft sensor was already replaced. Ran codes, cleared several times, no change. All the same codes. So it didn't work.
Had spark plugs all replaced 45 days ago so it's not that.
The words on the scanner said "'misfire" "egr valve" "fuel" "o2 sensor" "catalytic" "comp"
Ugh. Thoughts??
Maybe it's the ECM/PCM
Old 07-26-2017, 09:27 PM
0300 is multiple random misfire.
2302 P2302 Ignition Coil A Sec Circ (ignition coil A, secondary circuit, this would certainly give you misfires.)
P0335 Crank Pos Sens Circ
P0339 Crank Pos Sens Circ Interm
P0052 HO2S Heater Ctrl Circ Hi Bank2 Sens1
You have two codes there for the crank sensor. I would be curious what brand sensor the last guy put in there. If it is was just some cheapy from the local parts store, that may be most of the problem right there. Dodge trucks are notoriously picky about there sensors.......
I would also put the original cam sensor back in. None of the codes relate to it. (return the 'new' one??)
I would also be tempted to replace coil "A", whichever one that is....... (I don't have a clue, that motor is coil-near-plug, is it not??)
What year is your truck?
Old 07-27-2017, 02:01 PM
Kimberly Collins
The crank sensor would have been one from O'Reilly and the part was around $28.
I put a new cam sensor in because there was another thread through Direct Hit that said sometimes a cam sensor can throw a crankshaft code. So I tried it, and it obviously didnt work. Why would I have two crankshaft codes?
Yes the motor is CNP.
My truck is 2008 with 133k on it.
