Harmonic balancer went bad, it's bouncing around on the crank shaft
So, my harmonic balancer is clattering, and moving around on my crankshaft. I'm trying to find out what if tools I need to replace this, and any advice from those that have done it before?
I've never had to pull my belts off before, so I'm not sure If I need special tools for that, plus I hear you need a special dodge branded "puller" to remove the harmonic balancer?
My truck is a 2001 ram 1500, 2wd.
I'm not sure what socket size I even need for the crankshaft nut.
Since you don't care if you screw up the old balancer, you can use whatever puller you happen to have, that will actually get a grip on it, and pull it.
You should only have one belt, just grab ahold of the tensioner with the appropriate tool, relieve some tension, take the belt off one pulley that is easy to reach, then slowly release the tensioner. The sometimes have a hole in 'em for a 3/8ths ratchet, or maybe a block on the end you can grab with a wrench. (or even, the end of the bolt on the tensioner pulley.....) Do NOT remove the bolt that holds the tensioner to the engine. Bad things happen when you do that.
Which engine do you have? They are both a pain in the butt. I've done two - one with the shroud and accessories off and one with everything on. They are different for 5.2 and 5.9. The latter has spokes while the former is solid. You can only get a replacement for the 5.9 at shops. If you have the 5.2 you'll have to go junk yard or dealer. If you've never even replaced a belt before, I'd take it to a shop for the balancer. It's not easy.
This thread discusses the removal - shows an innovative way to remove it using a standard harmonic balancer puller - https://dodgeforum.com/forum/2nd-gen...ancer-off.html
Also, that balancer should be available in the aftermarket. Here is an example - https://shop.advanceautoparts.com/p/...onic+balancers
I've got the 5.9 gas engine.
I've done a decent bit, just never had the occasion to do a belt. It looks simple enough, but If I'm in over my head I'll need to just take it in and not waste my time. I recently replaced the wheel bearing and brake calipers and this job doesn't seem much harder based on youtube.. :P just pull the nut, pull the HB ,install new HB and torque nut. Am I missing something big?
Not supposed to use an impact to remove/install the dampener. However, im sure many people have without issues.
To be safe i'd use a large screw driver or something similar to lock the dampener in place (keep it from rotating) and use a ratchet to remove the bolt holding it on.
