3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hello all, I'm in a big bind, I had my turbo re-built and after I installed it, it thru a p2262 code (turbo super charger boost pressure not detected.) I did a EGR valve and cooler clean also, so the re-build guy told me to bring it back and he would check it. said everything fine but changed actuator for my peace of mind. well long story short I've had the turbo out 4 times now with that same code. I'm at my wits end and on the verge of a nervous break down. lol. obviously it seems to be something else can anybody help please.
Thanks Ritchie
Reason: add text
It had a CEL I forgot what the code was, but dealer said that they could clean it but they wouldn't guarantee how long it would last, so they said to have turbo re built.
Aside from that, I would be tempted to warranty replace the actuator and such again. Also need to verify that the parts that are supposed to move, actually can....
The last time it happened, I took it to a diesel mechanic. It drove fine their but when I picked it up the truck had no power. they said turbo was running at 20% after their test. had to limp it home.
