2001 Dodge Ram 1500 42RE
Old 10-09-2017, 11:55 AM
tima818's Avatar
tima818
tima818 is offline
Default 2001 Dodge Ram 1500 42RE
I am getting Code P0753 Shift Solenoid A Electrical. I look at Autozone and they 2 solenoids 1) Overdrive and 2) Governor? Which one would be the shift solenoid? Trucks seems to be in limp mode. Only get 3rd gear. 2001 Dodge Ram 1500 2 wheel drive 42RE transmission. I reset check engine light and P0753 comes back as soon as I started it. I reset it with a scan tool and well and disconnecting the battery. Any help would be appreciated.
Old 10-09-2017, 07:44 PM
That would be the O/D solenoid. Verify you are getting power down TO the trans.
Old 10-09-2017, 08:03 PM
tima818's Avatar
tima818
tima818 is offline
I assume I will have to drop pan and disconnect plug from solenoid and check for 12 volts? Just turn on to check for voltage?
Old 10-09-2017, 08:09 PM
Nope, there is an 8 pin connector on the trans, drivers side, 'bout halfway back. It can be hard to see if you have 4 wheel drive.... plugs straight down into the top of the valve body. You can unplug that, and the fat red wire should have 12 volts with the engine running. (or, for about 3 seconds when you just turn the ignition on.... without starting.)
Old 10-09-2017, 08:25 PM
tima818's Avatar
tima818
tima818 is offline
So no 12 volts PCM issue?
Old 10-10-2017, 09:04 AM
Not necessarily. Might be a blown fuse, bad relay, broken wire..... many possibilities.
Old 10-23-2017, 01:29 PM
tima818's Avatar
tima818
tima818 is offline
Do I have to remove valve body to replace the shift solenoid?
Old 10-23-2017, 02:24 PM
Nope. Drop the pan, pull the filter, sensor and solenoid are right there.
Old 10-23-2017, 02:58 PM
tima818's Avatar
tima818
tima818 is offline
Is the round plug easy to get too?
Old 10-23-2017, 09:49 PM
Not really. Especially if you have a 4x4. Crawl under and have a look, you'll see what I mean.
