2005 dodge dakota 3.7l 4x4
Old 01-22-2018, 08:29 PM
Roldog123's Avatar
Roldog123
Roldog123 is offline
Default 2005 dodge dakota 3.7l 4x4
I have an issue..in have a 4speed transmission and when I get to the 4th gear my truck starts hesitate and my rpm just around aliitle and I lose a ittle power. But once I open the trottle up it goes away..just wondering what it.might be..any help is appreciated.
thanks.
Old 01-22-2018, 09:30 PM
Received 3,207 Likes on 2,959 Posts
Welcome to DF! Post your questions in the Dakota section.
Old 01-23-2018, 06:49 PM
Roldog123's Avatar
Roldog123
I'm having an issue with the throttle because when I go to 4 gear it hesitates but when i open up the throttle it goes away
Old 01-23-2018, 09:44 PM
jkeaton is offline
You have a manual 4 speed transmission in a 2005 Dakota?
Old 01-23-2018, 09:52 PM
Roldog123's Avatar
Roldog123
No, It's an automatic. And it' a 4 speed transmission. So when j fetntonthe last year it's starts hesitating but goes away when I open up the throttle..
Last edited by jkeaton; 01-24-2018 at 07:42 AM. Reason: Tried to fix the horrid spelling....
Old 01-24-2018, 03:38 AM
FaceDeAce's Avatar
FaceDeAce
FaceDeAce is offline
There are truthfully quite a few possibilities. It can get expensive just replacing stuff. We will need more information to help narrow it down.
Is there a check engine light on? Has an OBD reader been hooked up to check for and read any codes present?
Old 01-24-2018, 07:44 AM
jkeaton is offline
Please take a few seconds and read what you type before posting. I tried to fix your post but have no idea what you are trying to say. Spelling, grammar and punctuation goes a long way in helping us help you.....
Old 01-24-2018, 11:46 AM
Roldog123's Avatar
Roldog123
No engine light on and I am thinking it' either the mass air flow sensor or.maybe the ignition coil..I had a similar problem when I had a Lincoln is and it was hestaiting going up hill..also May be the throttle position sensor??
Old 01-24-2018, 11:57 AM
FaceDeAce's Avatar
FaceDeAce
- spark plugs
- ignition coils
- ignition wires
- IAT sensor
- TPS sensor
- MAP sensor
- crank sensor
- knock sensor
- fuel pump
- injector
- O2 sensor
- dead cylinder
Could start replacing stuff. Gets expensive. Better to come up with a diagnostic plan of attack. When at a loss of where to start or how to check, sometimes it is best to take it to a reputable mechanic to diagnose. Once known, then decide whether to take on the repair/replace yourself or have the mechanic proceed.
Quick Reply: 2005 dodge dakota 3.7l 4x4
