change tire size for winter
Old 10-17-2018, 10:53 AM
00Canuck's Avatar
00Canuck
00Canuck is offline
Default change tire size for winter
I want to change my 20's for 17's for the winter and did it in the past with a 2010 but with the 8 speed transmission in the 2014 I now own, is it a good idea? If so is there a program I need to change for the speedometer etc? Thanks in advance for any help.
Old 10-17-2018, 11:35 AM
Noelie84's Avatar
Noelie84
Noelie84 is offline
As long as you pick a tire with the same outside diameter as your 20's it should be fine, without needed to change the speedometer. What size do you have for 20's; the 275/60R20's?
Old 10-17-2018, 12:43 PM
jkeaton is offline
Make sure the 17's clear the front calipers.
Old 10-17-2018, 01:16 PM
00Canuck's Avatar
00Canuck
00Canuck is offline
Noelie84, yes that is the tire size currently on the truck. I have 265/70R17's that I want to run for the winter. For the 2010 I used a Diablo Predator and a program in it to change things and it worked very well. That's not necessary for the 2014? I'm a little concerned about the trany. Thanks for the tip jkeaton!
Old 10-17-2018, 03:51 PM
Noelie84's Avatar
Noelie84
Noelie84 is offline
Ok. Going to a 265/70R17 will drop your tire overall diameter by about 1.3 inches and may mean needing to have the speedo changed. Your local service department should be able to tell you for sure, or possibly somebody in here who's done it can chime in about whether they had to or not. A 285/70R17 will keep the diameter within 2/10ths of an inch, but would probably mean getting E-load tires.
FWIW, the 17" wheel should clear your calipers fine, since that size has been the base option on most years of the 4th gen trucks and they don't increase rotor diameters or use different calipers for different trim packages.
Old 11-17-2018, 08:45 PM
kayakman's Avatar
kayakman
kayakman is offline
Here's a link 00Canuck, I put it in metric, I'm guessing you're in Canada like myself. You can change it to imperial by clicking on the box where it says metric and a drop down box will open. Ram's with 17" wheels are usually 265/70R-17 but tire shops usually recommend the 285/70R-17 when downsizing to 17" wheels as Noelie84 stated. Going from 20's down to 17's tire shops usually won't recommend the 265/70-17
https://www.1010tires.com/Tools/Tire...&ismetric=true
Old 11-18-2018, 01:26 AM
primem's Avatar
primem
primem is offline
delete post
Old 11-19-2018, 03:29 PM
00Canuck's Avatar
00Canuck
00Canuck is offline
Thanks kayakman,
Well the 265's are what I have and what I ran on the 2010 without issue once the program change was made. My biggest concern is the newer 8spd transmission and how the tire change may affect it.
Old 11-19-2018, 03:33 PM
kayakman's Avatar
kayakman
kayakman is offline
Thanks kayakman,
I doubt if you'll feel any difference. 00Canuck
cheers
kayakman
Quick Reply: change tire size for winter
