Transfer case noise
Transfer case noise
Hiya all 2001 durango 4.7 4x4 233 transfer case 250000 miles my question is I heard a popping/ grinding noise a month or so ago in the snow . I finally got it in the shop up on 4 jack stands with it in 4hi or lo no noise. When I hit the brakes the transfer case makes the popping /grinding noise let off the brakes no noise with the truck on the ground the noise is intermittent. Do I need a fluid change or should I be looking for another tc?
With that many miles on it, I wouldn't be at all surprised if it weren't the chain slipping on the gears.......
Put it up on the rack, in 4wd, engine off, trans in park. (and make sure 4wd is actually engaged.) Set the parking brake as well. Now, grab the FRONT driveshaft, and turn it in one direction till it won't turn any more. Then, turn it the other direction, and see how far it turns, without the rear shaft turning as well (there is always some slop in the spider gears and such in the rear diff, so, it will likely be able to turn a bit, even with the e-brake set.). It *shouldn't* be very far at all. If you get an excessive amount of movement though, (pushing a quarter turn) the chain is in need of replacement.
Transfer case noise
Ok I did what you suggested and the driveshaft moved about 2 ins in either direction. I also checked the fluid and it was low add that and the noise is still there but not as bad so I guess a rebuild is in order. Any suggestions on where to find a book for this I want to do it myself. Thanks for all the input. And....... on a final note for the night I have discovered the both capacitors by the coils are unplugged but I cant find the connectors and insight is greatly appreciated
The first time my Durango saw dirt after finally getting a set of mud tires put on I heard the terrible transfer case pop. Figured out what it was very quickly and easily. The chain stretches over time then starts slipping. Dodge apparently thought it was a wonderful idea to not put a front differential "lockout" on these so that chain spins full time no matter what mode you're in. So if you're in a financial pinch, pull the front driveshaft until you can replace your chain. I haven't had 4wd for a couple years for that and some other reasons. But that'll stop your chain from spinning.
Reason you should pull the driveshaft is, you don't want the chain to bind up and snap when you're doing 70mph down the highway. Things get real nasty real fast.
Originally Posted by deanbw
Did you pull the back off to see it was the chain? I only ask because it is rare for that to happen. I thought the same thing until I took my case apart and found it was the plastic guides on the shift fork had worn through and the shift fork being aluminum had worn thin and would not throw drum all the way over to engage 4wd so under any load more than a straight line it would pop, and pop loud.....6 dollar set of fork guides and a little welding up the fork....all is good, well I put in a new chain while I was there, but it wasn't much different than the one I took out.
Not to say I don't have other issues inside as well, with now 270k-ish surely there's some wear inside. I'll find out when I tear into it and likely will be putting fork guides in as well. I have the NV242 incase anyone is wondering or it makes a difference.
