Dodge 3500 rear ends
Old 07-21-2019, 08:01 PM
Travis Atkinson's Avatar
Travis Atkinson
Travis Atkinson is offline
Default Dodge 3500 rear ends
I have a 97 Dodge 3500 dualy . It has 3:55’s in it but I found a 2000 3500 cab & chasis with 4:10’s. My question is will the 2000 interchange with mine? Thanks
Old 07-21-2019, 09:49 PM
I think there are some minor differences, maybe the rear wheel speed sensor, but, aside from that, it should bolt in. If you have an auto trans, you should have a Dana 70 rear though, and the cab/chassis might be an 80. Mounts and such are all the same still, I think the axle tubes are larger diameter....
Old 07-21-2019, 10:32 PM
Travis Atkinson
Mine has a 5 speed in it. Thanks
Old 07-22-2019, 08:18 AM
Should be a D80 in yours then. Makes life easier.
What is wrong with your current rear diff??
Old 07-22-2019, 08:41 AM
Travis Atkinson
Nothing that I know of. I pull a GN trailer with skid steer ‘ mini x a lot. Both weigh 10K. Just thinking I might like 4:10’s better.
Old 07-22-2019, 09:04 AM
Highly likely.
Have you considered just changing the gears?
Old 07-22-2019, 09:22 AM
Travis Atkinson
Highly likely.
Yes. That was what I meant to ask in original post just didn’t make that as clear as I should’ve. Mechanic I use has a wrecked truck with the 4/10’s in it. Was just curious if hears were interchangeable
Old 07-22-2019, 11:26 AM
If they are both D80's, then they certainly should be. Does either rear have the limited slip diff?
Old 08-04-2019, 04:53 PM
u2slow's Avatar
u2slow
u2slow is offline
DRW in a 2ndgen is a Dana 80. The pickup diff is wider than the cab & chassis by about 4".
The Powr-lok was discontinued around '98. Best you will find in a '00 diff is the trac-lok, unless somebody has upgraded since.
Old 08-05-2019, 10:52 PM
00t444e's Avatar
00t444e
00t444e is offline
2nd gens Duallys had the Dana 80 regarless of the transmission. If you do a few modifications to that Cummins under the hood you won't need 4.10 gears.
Quick Reply: Dodge 3500 rear ends
