03 Dodge misfire?
Old 04-27-2024, 01:38 PM
freberd's Avatar
freberd
freberd is offline
Default 03 Dodge misfire?
Dodge 2500 5.7 has about 160k I have been having stuttering/accelerating problems for the last couple months. Feels like bad gas
comes and goes
Have replaced
spark plugs
2 O2 sensors
pvc valve I think that's the name
Throttle body
Accelerator pedal cable and sensor
Still acting up
Codes is PO132
then
Misfire
Catalyst
Evaporative
I have no clue where to go from here
Could it be catalytic converter?
Maybe we bougot bad O2 sensors?
Appreciate any guidance
love this truck it's been dependable and haven't spent a lot of $ until recently
Old 04-27-2024, 01:55 PM
HeyYou is online now
Received 3,206 Likes on 2,958 Posts
What brand O2 sensors? Were you getting that code before you replaced them? What plugs did you install?
Old 04-27-2024, 02:56 PM
freberd's Avatar
freberd
freberd is offline
Default 03 dodge misfire
I've been reading through several pages trying to gather information
We bought O2 sensors aftermarket don't remember brand
I'll try to look for receipts
We replaced plugs with iridium?
I have noticed copper is recommended
The reason replaced plugs was because the truck was just starting to act up
Old 04-27-2024, 04:10 PM
The iridium plugs may have made the problem worse, not better. It's a real crap shoot with the rare earth fellers, some folks have nothing but problems with them, others have no problems at all. Running plain jane coppers is a troubleshooting step in this case.
Old 04-27-2024, 04:37 PM
freberd's Avatar
freberd
freberd is offline
Going to try the instructions for calibration of pedal
Maybe ground Throttle body
We had no codes till after spark plugs installed about a 6 weeks later is when problem really started
Then I guess replace spark plugs
Old 04-27-2024, 05:25 PM
Alex Medeiros's Avatar
Alex Medeiros
Alex Medeiros is offline
Yup as @HeyYou said these trucks hate anything other than copper plugs. Those aftermarket sensors are also not good to use, as the OEM ones are the best way to go or at least a very highly rated brand.
Old 04-27-2024, 05:33 PM
freberd's Avatar
freberd
freberd is offline
We could never get the O2 code to reset after replacing sensors
Ill check with dealer
Are there only 2 sensors?
I thought I read someone mentioned another
Thanks for the help
Old 04-28-2024, 10:50 PM
freberd's Avatar
freberd
freberd is offline
We recalibrate as we have read in this forum
using Throttle
engine light blinked while moving pedal
Switched out spark plugs for copper ones
still sounds horrible worse in park
RPMs jumping all over the place
above 35 mph not to bad
I guess tomorrow will order Mopar O2 sensors to replace the aftermarket ones we bought
any other suggestions?
Old 04-29-2024, 11:29 AM
freberd's Avatar
freberd
freberd is offline
In park it runs rough but in gear it sounds better
that should be a clue to help solve problem
Any ideas?
Old 04-29-2024, 02:31 PM
freberd's Avatar
freberd
freberd is offline
Called dealer to order O2 sensors
they have our Vin # saying we should have 4 o2 sensors
We only have 2 have only 2
Dodge ordered them $360
lets hope the code goes out when we put them in
Still need ideas why not running correctly
Quick Reply: 03 Dodge misfire?
