Dead and not starting
Old 07-11-2024, 08:29 PM
Joner's Motors's Avatar
Joner's Motors
Joner's Motors is offline
Default Dead and not starting
I have a 1992 d150 318 swapped into a 1956 Dodge Regent. I drove it to work today and it worked fine. Once it was time to leave, I started it to let it warm up. It ran for a minute and died. When it started it revved up, lowered to idle, dropped below idle, lost cylinders, and stopped altogether. I had to get a ride home because it wouldn't even try to start again. Any ideas?
Old 07-12-2024, 06:34 AM
Moparite's Avatar
Moparite
Moparite is offline
Efi or carb?
Old 07-12-2024, 07:11 AM
Machomur's Avatar
Machomur
Machomur is offline
Pull the fuel line off the output side of the fuel pump and have someone turn the engine over to see if the pump is good.
Old 07-12-2024, 12:15 PM
Joner's Motors
Originally Posted by Moparite
Efi or carb?
Fuel injected
Old 07-12-2024, 12:16 PM
Joner's Motors
I heard the pump start, but I'll check it again.
Old 07-12-2024, 12:29 PM
Machomur's Avatar
Machomur
Machomur is offline
Oh, you have electric pump. I was thinking mechanical.
Old 07-12-2024, 05:44 PM
ol' grouch's Avatar
ol' grouch
ol' grouch is offline
Shoot some starting fluid or brake cleaner (that doesn't say non-flammable) into the intake. If it starts for a bit then dies, you have a fuel supply problem. I'm thinking your fuel pump or pump relay might have gone south. If it won't start at all, you have an electrical issue.
Old 07-12-2024, 07:24 PM
Joner's Motors
The fuel pump is completely dead. I'm getting a new one tomorrow, so hopefully that fixes it.
Quick Reply: Dead and not starting
