Hey guys, I have a front dana 44 axle from a 2000 dodge ram 1500 and was wondering what bilstien shock fits stock stabalizer location because they don't make a kit it seems
Depends on how you drive and the conditions, Stock tires or lift?. All the stabilizer does is keep the steering wheel from being ripped out of your hand when you hit a pot hole/bump. It dampens any quick movements in the front end.
if I'm being honest I Have no idea what lift it would be for a dodge, it's on my 2003 yukon that I solid swapped. It's definitely lifted from what stock would be for a 1500 though, I just want something to help everyday driving
Make sure all the steering parts are in good condition, including the steering box.... that's generally where a lotta slop comes from. To find the rest, grab another warm body, have wb gently rock the steering wheel back and forth with the ignition unlocked, just to the point of feeling some resistance. (use two fingers....) You get to watch the steering gear. See what is moving that shouldn't, and what isn't moving, that should.
Steering stabilizer on my 98 is toast. I haven't bothered to replace it. There wasn't one on my 96, and I didn't miss it.
most of my driving is on gravel and bumpy off roading which jerks the wheel somewhat, trying to minimize that with a steering stabalizer setup, I'm thinking dual hydros on front and another on the factory location
All of the lift manufacturers also make steering stabilizer kits. If you have a dana axle from a dodge up front, just get one for the appropriate year/weight rating dodge truck, and call it a day. A dual stabilizer should be more than adequate to the task.
anything else you can think to make these axles smoother on the off road scene? It rides good now but just for future reference
Its the weight that gets ya. If you have big tires, that doesn't help either. Stabilizer is about all you can do though. That, and make sure all the linkages are tight.
