99 dodge1500,”No Bus” and Abs light, check engine, airbag light
Cant seem to figure out whats wrong with my truck, the check engine light is p0500 ive replaced the sensor on the rear axle and transmission,ohms read fine at the axle connector, Ive traced cables, im not getting any drops throughout, im at a loss. I just finished looking into the fuse box under the hood for corrosion
Reason: Title to long
You have something else on the 5 volt bus failing then. Start unplugging sensors, see if one of 'em gets the dash back.
I disconnected the Vss sensor, transmission tail shaft sensor, and the abs module. The same lights are still on. I might also mention I replaced all 3 sensors, what would u recommend I disconnect next?
Reason: Need to add something
[QUOTE=HeyYou;3591257]Anything on the 5 volt bus. Which is also most of the engine sensors.[/QUOTE
Is there anything i can do to rule out where i should start disconnecting?
Thank you i will try that tomorrow, i also tested everything I disconnected with a multi meter and got 5v. Also when i drive around and look on my code reader the VSS will cut out and drop to 0 at times
Reason: Change
