HID Special $60.00 Shipped for Dodgeforum members
#511
SAME PROBLEM. Fogs work great no problem. I also was under the impression I needed capacitors for this sytem by reading all the information on these systems, however when I requested them I was told I needed the relay only. My driver side light turns on fine with the truck off or on. The passenger side light will flicker for almost 15 seconds and only sometimes turns on if the truck is off. IF that bulb eventually turns on, I start the truck and the passenger side light again starts to flicker and only half the time comes on. Please Help
#512
Once I got rid of the RELAY and installed the Capacitors, no flickers of any kind. No lights alternate on or off when turned on, whether the truck is on or off, the lights work the first time. I don't know who at hidextra is recommending relays, but they're causing nothing but problems and a bad name for the company. Once again, I have the dual lights with capacitors, works 100% of the time and looks great.
#513
HI Kevin,
I'm going to send you a pair today, apparently, the last half of 2009 dodge rams need special capacitors and not relays , so sorry !
michelle
michelle
#514
Due to increasing number of HID inquiries, please allow me 24-48 hrs (excluding weekends and holidays) to respond to your PM, thread replies or Email.
All orders placed before 3pm PST yesterday have been shipped.
All Kits are shipped Priority mail 3-4 business days (give or take 1-2 days due to holiday delays)
All bulbs and accessories (non kit orders) are shipped First Class Mail which takes about 4-7 business days (give or take 1-2 days due to holiday delays)
Buy ANY two kits and get a free HIDeXtra.com License Plate Frame Free!
Ordering Instructions:
1.) Go to this link to check on bulb type
http://www.sylvania.com/ConsumerProd...lacementGuide/
2.) Then go to www.hidextra.com and choose the (BULB TYPE AND COLOR)
3.) Use Express checkout
4.) Input coupon code: fspecial-m to get $15 off the kit price
5.) IF you are purchasing more than one kit, please do SEPARATE transactions for EACH kit in order to get discount on all kits.
6.) Please note in additional comment area “Purchased two kits, want license plate frame”
Any questions, please email me @ info@hidextra.com
Thanks for all your support and business!!
Michelle
Michelle
#515
#517
I have a NEW problem with the HIDS I got from HIDnet.com
My fog lights are having the SAME issue as the driving lights. They had reserved wiring so they had to be cut and spliced into the factory wiring. They also were mounted at an angle/upside-down just like the driving lights.
I'm VERY unhappy at this happening with BOTH of my HID kits.
The HIDS work fine, but they shouldn't have been cut or spliced in the first place. They were advertised as "plug and play" and neither kit was.
#519
Hello,
I ordered a set and it got here on Friday. I was able to install the kit today. I havea 2002 Dodge Ram 1500. Bulb size is 9007. I got the hi/low kit, where the low is HID and high is hologen. I got the capacitor that came with the kit. I hooked it up and everything work as it should, but when I stop the car and turn the lights off.....they stay one for an additional 20-30secs. I assume this is the capacitor discharging, is this normal and does anyone else have this issue?
I think this will become a problem if i left my lights on by mistake and thinking that it would shut down after 30secs.
Please advise.
-D
Please advise.
-D
