So when I'm accelerating there is no whine but as soon as I release the pedal it starts whining with a little vibration at speeds above 50. If I repress the gas it goes away instantly. The sound is definitely coming from the rear of the truck. Hoping someone has some ideas. Thanks for the help.
Depends on which one is bad. Or both..... If its just the outer, not too bad of a job. If the inner is bad as well..... time for a shop, or, if you know a guy good with gears.... draft him.
Ok so the pinion bearings checked out the read driveshaft ujoint closest to the t case was really bad. So I replaced that some fluid came out so I wanted to fill it up but the bolt won't come off any ideas on getting the bolt off. It is starting to strip.
