My Official Solid Axle Swap Thread (The Discussion Thread)
Old Apr 4, 2010 | 01:46 AM
  #131
Crazy4x4RT's Avatar
Crazy4x4RT
Alright! Finally the truck look like a truck again!! Keep up the GREAT work!
Old Apr 17, 2010 | 12:21 AM
  #132
Az93DKota's Avatar
Az93DKota
Do you think he likes this truck or what?
Old Apr 17, 2010 | 10:43 AM
  #133
Crazy4x4RT's Avatar
Crazy4x4RT
That looks like fun. I would have a blast welding, cutting ect! So what happened to your welder? What mounts were you waiting for?
Old Apr 17, 2010 | 04:14 PM
  #134
95_318SLT's Avatar
95_318SLT
I was waiting for the upper link and upper and lower coil mounts to get here. I already started tacking the axle side upper link mount to the axle, and I was about to tack the frame side down when my welder started acting up.
I think the wire feed motor is on its way out in my welder. Either its the motor or the speed controller, but the welder can't seem to hold a constant wire speed, which makes it near impossible to weld with it.
It really sucks cause everything I have to do right now with this project involves welding!
Old Apr 17, 2010 | 06:58 PM
  #135
Crazy4x4RT's Avatar
Crazy4x4RT
I'm sure you know but a bad tip is the biggest contributer to slow/ sticking feed.
Old Apr 17, 2010 | 07:31 PM
  #136
95_318SLT's Avatar
95_318SLT
Actually, I honestly don't know much about welders.
But I don't think its a bad tip. I took the welder apart, and it looks like the speed controller is bad. I took all the gears out of the gearbox, pulled all the wire out of the gun, and ran the motor with no load what so ever and it still jumps around.
Old Apr 17, 2010 | 09:49 PM
  #137
LO 619's Avatar
LO 619
That sucks! What kind of welder are you using? Have you checked the cost of new parts?
Old Apr 17, 2010 | 10:00 PM
  #138
95_318SLT's Avatar
95_318SLT
I've been using my little 110 volt Craftsman Professional wire feed welder to tack all the mounts in place. I was going to rent a 250 amp engine driven welder for a day to secure all the mount's in place once they were all tacked down.
I haven't priced out parts yet. I just finally found out today what the problem was.
Old Apr 17, 2010 | 10:15 PM
  #139
SMKNRAM's Avatar
SMKNRAM
95 we sure missed having you today! check out the pics in the club section! Get that truck on the trail, you will have a blast at Uwharrie!!
Old Apr 22, 2010 | 09:25 PM
  #140
95_318SLT's Avatar
95_318SLT
Alright, well I got my welder fixed last night, so it was back to work today! Also, now that I'm a moderator, and have the ability to reorganize my thread when I'm done, I started the rear axle write up so ya'll can see what progress I've made there. I'll reorganize it when I finish.
