My Official Solid Axle Swap Thread (The Discussion Thread)
Old Mar 17, 2010 | 12:54 AM
  #111
burntricer's Avatar
burntricer
pics look good! im still payin attention so i know what im gunna have to do lol...
Old Mar 17, 2010 | 09:56 AM
  #112
dbilik's Avatar
dbilik
I want to see how it rides before I cut up my first gen. You use the POR-15 yet? Maybe I missed it in a previous post.
Old Mar 17, 2010 | 03:46 PM
  #113
95_318SLT's Avatar
95_318SLT
No, I haven't used it yet. I decided to do all the lining up and welding first, and then paint later. That way I won't have to grind off any paint for any reason.
Old Mar 18, 2010 | 12:32 PM
  #114
Crazy4x4RT's Avatar
Crazy4x4RT
Come on do the real work. Get started on welding it up!!!!!!
I forgot to ask. How was it to use the plasma cutter? I've only done small jobs with it.
Old Mar 18, 2010 | 01:59 PM
  #115
95_318SLT's Avatar
95_318SLT
Lol, the welding is coming up soon enough!! I can only tack the mounts to the frame with my welder... its too small to do the full job. I'm going to rent a big 200+ amp welder to secure all the mounts.
The plasma cutter is awesome!! It cut through that steel like butter! It took longer to prep the metal to be cut than it did to actually cut it. The only thing that sucks is you can't aim it into the frame without destroying the frame (at least I don't know how to), so you have to cut the mounts off and then grind out the remaining peices.
Old Mar 18, 2010 | 03:27 PM
  #116
Goose2283's Avatar
Goose2283
Sounds like a great buildup. I'm planning something similar for my '87. Subscribed!
Old Mar 20, 2010 | 12:49 AM
  #117
LO 619's Avatar
LO 619
oh my godddddddddddd!
Old Mar 20, 2010 | 01:09 AM
  #118
burntricer's Avatar
burntricer
lookin good man, but like youve stated, this is all the easy stuff. the hard stuff will be the steering etc. Im still shopping around but its gunna have to wait until i start working full time again (currently a student lol)
Old Mar 20, 2010 | 10:52 AM
  #119
95_318SLT's Avatar
95_318SLT
Well everyone, I have some really bad news. The radius arm suspension is not going to work. I don't know how I overlooked this, but the distance between the radius arm mounts is about 4 inches narrower than the distance between the frame rails. I don't know if there is a difference between the '76 and '79 F150s, since I've seen this swap work twice with the '79 F150/Bronco parts, but I'm calling it quits on the radius arm suspension. Time to go to plan B and design and build a 3 link.
Old Mar 20, 2010 | 12:39 PM
  #120
Crazy4x4RT's Avatar
Crazy4x4RT
LOL! Dang that sucks. Is there any way to build up some kind of cross member/ bracket to make it bolt up.
